Is there a way to rearrange the order for basic rules?
I've built some rules but found I needed to add something but after clicking Add Another Action, it will only put it at the end and I need it higher up.
Mine sort alphabetically. I assume yours do as well?
You could toggle the “Change the Basic Rule Name” on the bottom left of the rule and then set a name that sorts it in the order you need.
Also, welcome to the Hubitat community!
I assume you mean re-arrange the order of "actions" inside a Basic Rule itself? If that case, there is no way to do so, though it may make for an interesting feature request. This is possible with Rule Machine, and you can "import" Basic Rules into Rule Machine if you want more features, though it might be overkill just for this...
As a workaround, you can delete actions up to that point and then re-add new ones in the desired order. I can't think of anything else.
Thank you Bert, that's kind of what I figured but wanted to make sure I wasn't missing something obvious.
