I created this Basic Rule the other day, been working fine until today. the light came on at 9:43am and never shut off, even though we have been in/out several times
I don't see anything in that setup that should be problematic. I see you habe logging enabled, so looking there to see if you find anything suspicious would be a good place to start, as would hitting "Done" in the rule to re-initialize things (just not during that wait, probably), which it looks like you've done now too.
Can I assume your light responds to "on" and "off" commands as expected? That seems like the most likely non-app problem if your sensor is working correctly (can't see from that particular screenshot, but if you still have events from 9:43-ish AM, you can verify it stayed inactive for at least one minute). But I suspect you'll get better clues from logs if this doesn't work next time.
Thank you for the replies, yes logging is enabled and nothing was logged all day, no motion.... nothing
I have always used the illuminance of the living room motion sensor, this way I don't need to buy and install throughout the house. It's not perfect since I'm not reading the level in the area where the light is but it works very well
Well some of my basic rules continue to fail, seems like it's ones that have restrictions... ones that are based on motion starting/stopping seem to be good, ones based on say illuminance seem to fail pretty regularly...
As far as I know, there is no bug with this. I tested something similar yesterday. Please turn on logging, and post the logs for the Basic Rule when it runs and fails to turn off the light.
@bravenel things ran great yesterday and today until 3:15, no log entries after that and the motion that triggers the rule has been triggered many times since then
I have a rule almost identical to this (except without the mode and illuminance restrictions you have) that has been running without issue for quite some time..
@bravenel Is basic rules expected to cancel waits if the state of restrictions changes? (The Basic Rules documentation is not very clear on this and nothing about restrictions mentioned in the wait description.)
