Hello. Hope I am posting in the correct area. I am getting an error in a Basic Rule. It appears that the error is in my action that turns a GE Switch off 30 minutes prior to sunrise. Not sure if the error is related to the Switch's driver I'm using, or the Hubitat Basic Rule code related to the sunrise scheduling function. The rule appears to run and turn on and off the lights. However it does throw the error in the logs.
The switch I'm using is:
GE Enbrighten Z-Wave Plus Smart Outdoor Switch, 1-Outlet Plug-In (2nd Gen.), Weather-Resistant, Works with Alexa, Google Assistant, for Landscape & Seasonal Lighting, ZWave Hub Required, 14298,Black.
Here are screen captures:
Thanks in advance.
Ron
