@Hubitat_Staff I've found an odd Basic rule conversion bug in HE 2.5.2.139 - everything looks good and works:
But if you try to edit the trigger it's hidden:
As mentioned, the Rule does still work.
Others have seen this as has @gopher.ny .
Create a new condition. Any will do, don’t need to use it.
This (usually) lets you see/edit triggers.
Noted.
This didn’t work for me. I tried it on two rules that had the same issue.
There are two places to make conditions, RE area and Actions area.
I think only actions area conditions effect this.
I added an “if” and a condition then deleted the if, leaving the condition.
