Basic dim a light switch from 8 am to 6 pm
I am trying to set the light switch to 70% from sunrise to sunset and sunset 10% to sunrise....
Current like switch : Levi ton dimmer Zigbee light switch.
I left Home Assistant thinking this would be easier. This is painful can anybody show how to do this action in Hubitat?
I would try using the Basic Rule app. It can kind of walk you through it in an easy to follow method.
thank you figure it out :slight_smile:
  1. used the Run Machine rule
  2. Name your rule
  3. Then set the event trigger = set to physical Switch
  4. select device =switch to turn ON
  5. Create Condition = between two times (sunrise to Sunset)
  6. create new action = Set Dimmer and Bulbs
  7. set dimmer
  8. Select Device
  9. set level (10 -100)
    10 . Repeat to create Sunset to Sunrise)
    11 Install rule
Done!
Glas you got it. It's hard to visualize your solution. A picture is sometimes clearer that text.
If you add yourself to the owners group, then you can paste a screen shot of your rule.
