Mind sharing the rule with me?
See this update - Moving from Wink - Shade Woes in Hubitat. Help!
Old thread dredge here. I was having erratic results with one shade in particular (2 others worked ok). The blind would work fine for a while, but then it would go up and not respond again. I could usually make it work by pressing the button on the blind a few times but not via hubitat.
In my case, it seems that the bind was binding slightly at one end. Perhaps I didn't hang it quite level but the edge of the blind was rubbing up against the housing at one end. I took a pair of sewing scissors and trimmed a few mm from that end of the vinyl all the way along the edge and now it has been working reliably. If you have fancier material that can't be trimmed, it might be better to re-level the shade.
@dpeeling
Did you ever get the 11.3 firmware for the Bali Blinds? I have it
