For my setup I have a Baldwin lock with the Schalage FE599/BE369 Z-Wave and 3 feet from that is a C6 Repeater.
I am attempting to use the Lock Manager un-successfully. But what is strange is that I can create a code inside of the Lock Manager and it will fail. Then I go the door and use the code that I created successfully I am able to unlock and lock the door.
The Lock does not route through the repeater instead it goes to the Hub Directly and there is a lag.
With Schlage (maybe all locks?) you can't read existing codes on the lock. You have to erase all the codes, and start over using Hubitat to add the codes. Did you try that?
Not sure what that is? What brand?
There is almost no way for users to control routing. You might get lucky by trying to include the lock again near the repeater, or trying a repair on a particular Z-wave node. You could also try moving the repeater. But it is often pretty futile trying to force what you perceive to be the best route. Lots of times Z-wave routing makes no sense to us, but does to the mesh for some reason.
Please screenshot your Z-wave Details page (all the columns on that page) and post it here. You may have to join the Owner group Hub owners - Hubitat to have permission to post pictures.
0xOB for example, and the other ones that say "Discover". They are incomplete or failed pairing of other devices. 0x0B is probably from 0x0C device failing to pair the first time.
Click Refresh, and see if a Remove button appears. Click Remove and hopefully these go away. Sometimes these ghost are tough to remove, but try these basic steps first and see what happens.
Yep there are not a lot of people with my name . You are correct about the ghost they are hard to remove. What if I don't remove will it effect my front door lock?
You need a z-wave stick. Zooz has a good one. If you're at work though you should be able to hit refresh on those lines until the remove button comes up. When you click remove, wait and see if a popup comes to that said force remove
Nah it's step by step instructions. Very easy to do... Just need to use a windows pc.
The only other option is to reset the z-wave radio on hubitat and factory reset each and every device in your mesh and re pair it. Any time you have a failed pairing, you need to check for a ghost and remove it, then factory reset the device and attempt pairing again. It's an issue with the SDK from SiLabs, NOT hubitat.
