Azoula Zigbee switch detected as RGBGenie Micro Zigbee Dimmer
Hello.
I bought this switch for testing: Amazon.com Azoula Zigbee Dimmer Switch. In the manual, it says it supports a bunch of Zigbee clusters including scenes, electrical measurement, etc... However, the driver that was picked up was RGBGenie Micro Zigbee Dimmer which doesn't seem to support those clusters.
Is there a way to expose the additional clusters in some way or use a different driver?
Here is the "Data" portion of the device page...
  • endpointId: 01
  • application: 00
  • firmwareMT: 1224-007F-0000003A
  • manufacturer: Sunricher
  • model: HK-SL-DIM-US-A
  • softwareBuild: 0000003A
I'm happy to provide additional details as needed.
I think it should be fine, I have the same dimmer on my C4 hub and it works and picked the same driver-good signal repeater as well. I think they're all made by the same company. Mine appears to be a slightly newer firmware
  • endpointId: 01
  • application: 00
  • firmwareMT: 1224-012C-0000003A
  • model: HK-SL-DIM-A
This is mine, neutral free version
https://www.amazon.com/gp/product/B0CQKTCHL4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Hey I didn't answer your question ! We would need to find another driver or ask Mike to update the built in driver.
@mike.maxwell can you consider adding the fingerprint to the rgbgenie dimmer driver?
dev:90552024-05-17 06:02:10.155 PMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,0008,0702,0B04,0B05,1000", outClusters:"0019", model:"HK-SL-DIM-A", manufacturer:"Sunricher"
Yeah, the driver works fine for the basics... but if we can expose the other clusters, that would be really nice.
How did you get that fingerprint?
