Away Mode automations C8
Ive noticed lately my Away Mode automations are not taking place. I looked at the logs and the commands take place on the hub when everyone has left the house. I just dont see the automations occurring. I just see the modes changing from Home to Away. I dont see the lights turning OFF or the thermostat turning to OFF.
I go into the App section and click the RUN button and it completes the automations.
Not sure if this has anything to do with the last 2 updates. I just noticed this.
Thankyou in advance
Ty
Try enabling logging for one of the automations to catch the failure. Post the logs along with the automation setup (whether that's room lighting, RM, etc.).
dev:82023-05-07 10:32:22.994infoThermostat temperature is 67°F
app:432023-05-07 10:31:11.250infoapp: When Angela, SM-S901U all have left …
app:432023-05-07 10:31:11.248infoapp: initialized
app:432023-05-07 10:31:01.600infoapp: When Angela, SM-S901U all have left …
app:432023-05-07 10:31:01.599infoapp: Finished
app:432023-05-07 10:31:01.596infoact: Set mode Away
app:432023-05-07 10:31:01.378infoact: Lock Garage SIDE Door, Front Door Lock, Garage Direct Door
dev:82023-05-07 10:31:01.364debugsetCoolingSetpoint(88.0)
dev:82023-05-07 10:31:01.343debugsetHeatingSetpoint(50.0)
dev:82023-05-07 10:31:00.814debugsetThermostatFanMode(auto)
dev:82023-05-07 10:31:00.154debugsetThermostatMode(off)
app:432023-05-07 10:31:00.144infoact: Control thermostats Thermostat to mode:off fan mode:auto heat:50.0 cool:88.0
dev:412023-05-07 10:31:00.125debugoff()
dev:382023-05-07 10:31:00.104debugoff()
dev:292023-05-07 10:30:59.983debugoff()
dev:282023-05-07 10:30:59.940debugoff()
dev:272023-05-07 10:30:59.922debugoff()
dev:242023-05-07 10:30:59.866debugoff()
dev:232023-05-07 10:30:59.845debugoff()
dev:212023-05-07 10:30:59.808debugoff()
dev:192023-05-07 10:30:59.770debugoff()
dev:182023-05-07 10:30:59.751debugoff()
dev:162023-05-07 10:30:59.712debugoff()
dev:152023-05-07 10:30:59.693debugoff()
dev:132023-05-07 10:30:59.649debugoff()
dev:122023-05-07 10:30:59.622debugoff()
dev:22023-05-07 10:30:59.535infoGarage Light is off [digital]
app:432023-05-07 10:30:59.467infoact: Turn off Garage Light, Spare Switch 3, Hallway Light, Entry Chandelier, Dining Room Chandelier, Dining Room Light, Living Room Light, Stairway Floor Light, Stairway Light, Family Room Light, Island Light, Kitchen LED Light, Kitchen Light, Breakfast Light, Kitchen Sink Light, Spare Switch 2, 1st Floor Bathroom Light, Spare Switch 1, Ava Bathroom Light, 2nd Floor Hallway Light, Mood Light, Spare Switch 4, Spare Switch 5, Master Bedroom Closet Light, Guest Room Light, Master Bathroom Light, Ava Room Light, Master Bedroom Light, Backyard Lights, Master Bedroom 2 Light, Office Light, Patio Light, Waterfall
waterfall switch
command-off Command called: off DEVICE command AWAY Ty, Angela Lights OFF and Doors LOCKED 2023-05-07 10:31:00.132 PDT
switch on Waterfall was turned on DEVICE digital Waterfall * Amazon Echo Skill (deviceHandler) 2023-05-07 10:28:21.326 PDT
command-on Command called: on DEVICE command Arrival Unlock Door Waterfall ON 2023-05-07 10:28:19.221 PDT
command-off Command called: off DEVICE command AWAY Ty, Angela Lights OFF and Doors LOCKED 2023-05-07 10:26:11.777 PDT
command-off Command called: off DEVICE command AWAY Ty, Angela Lights OFF and Doors LOCKED 2023-05-07 10:24:03.297 PDT
switch off Waterfall was turned off DEVICE digital Waterfall * Amazon Echo Skill (deviceHandler) 2023-05-07 10:23:33.567 PDT
command-off Command called: off DEVICE command AWAY Ty, Angela Lights OFF and Doors LOCKED 2023-05-07 10:23:30.789 PDT
switch on Waterfall was turned on DEVICE digital Waterfall * Amazon Echo Skill (deviceHandler) 2023-05-07 10:22:45.446 PDT
command-on Command called: on DEVICE command Arrival Unlock Door Waterfall ON 2023-05-07 10:22:17.545 PDT
command-off Command called: off DEVICE command AWAY Ty, Angela Lights OFF and Doors LOCKED 2023-05-07 10:21:34.620 PDT
garage door direct
|command-lock|||Command called: lock|DEVICE|command|AWAY Ty, Angela Lights OFF and Doors LOCKED||2023-05-07 10:31:01.588 PDT|
|battery|76|%|Garage Direct Door battery is 76%|DEVICE||||2023-05-07 10:28:34.512 PDT|
|lock|unlocked||Garage Direct Door was unlocked [digital]|DEVICE|digital|Garage Direct Door|* Lock Code Manager (useHandler)
Away automation
When a ...
Presence Sensor
Choose Presence Sensors
Angela
SM-S901U
Senses that
Everyone has left
Do this action:
Turn off
Select switches to turn off *
Ava Bathroom Light
Ava Room Light
Backyard Lights
Breakfast Light
Dining Room Light
Entry Chandelier
Family Room Light
Garage Light
Guest Room Light
Hallway Light
Island Light
Kitchen LED Light
Kitchen Light
Kitchen Sink Light
Living Room Light
Mood Light
Office Light
Patio Light
Spare Switch 1
Spare Switch 2
Spare Switch 3
Spare Switch 4
Spare Switch 5
Stairway Light
Waterfall
Delete
And do this action:
Control thermostats
Select thermostat *
Thermostat
Select thermostat mode
off
Select thermostat fan mode
auto
Heating setpoint
Cooling setpoint
Delete
And do this action:
Lock
Select locks to lock *
Front Door Lock
Garage Direct Door
Garage SIDE Door
Delete
And do this action:
Set mode
Set Mode to *
Away
Delete
Add Another Action
Add Wait Until …
Add optional restrictions that limit when this rule runs
Click to set
Change the Basic Rule Name?
Enable Logging
the logs indicate the Automation is triggering. However the devices are not completing the automation.
I ran the Away automation and Arrival automation
Screenshots please.
I created a seperate automation that executed on Mode change instead of presence. When Mode changed to Away it would send the command for devices. I'm getting the same response where devices won't execute.
So in looking in device history. I see the command prompt (either turn off the switch or lock the door lock). However there is no execution. This is consistent in both automations whether by Presence or by Mode Change
I then tested by going to dashboard if I can manually switch On or Off and Lock and Unlock. I've also openned the automation to RUN the automation and everything executes fine. Certainly ODD.
I spent the last hour on/off my automations and confirmed that for example my door lock is NOT executing to LOCK on the automation. I have to run the automation at least 2 or 3 times in order for the door lock to execute on the automation.
When I am on the dashboard. I can Unlock and Lock the Doorlock without any problems.
The same issue is with my thermostat and switch to the waterfall although not as consistent as the Doorlock.
On the Doorlock it Unlocks on the Arrival Automation with No problem at all. On the Away automation it won't lock on 1st command. I have to run the automation 2 or 3 times consecutively in order for the Doorlock to Lock. As I said...on the Dashboard I have no problem Unlock or Lock for the Doorlock. It's only on the Away automation.
Still the same scenario. Post screenshots of the rule along with logs from the device(s) and the app.
I ran the Automation for AWAY at 327pm
That's a lot of things being changed at once. I imagine you're flooding the Z-Wave network so devices are missing commands. I would break this up into different rules or use other apps to control some things. Like the lights...you can put them into a Room Lighting instance, add an activator device (just fill out the name in the box at the bottom of the app page) and just turn the activator device off in the basic rule.
Ok I will look at that.
It's just odd. It used to work absolutely fine until the last couple of weeks....
Something is definitely not right. I made some changes to the AWAY automation to where only the Thermostat, Waterfall switch, DoorLock, and Mode to AWAY.
Only 3 physical switches. I eliminated ALL my other switches in the automation.
Doorlock fails to LOCK and Waterfall switch fails to turn OFF.
Pretty consistent. This was to test out your theory of too many things happening to the Zwave network at once.
Again I Ran the Automation a 2nd time just now.
The Doorlock LOCKS and Waterfall Switch turns OFF now....
so something is going on here
Take a screen shot of your ZWave Details page. You might have a ghost device.
are you referring to Zwave Logs ? I pulled up the page but it's blank
Settings / ZWave Details
Looks like this
