Avoid Keen vents at all costs *scam*
I had the original Keen vents and never had an issue with the batteries when I had them. I have 2 suspicions, one is that you should always say them between 10 and 90% as I think they might Have issues at the extremes. Or the newer vents are more cost effective to build, but have issues.
Interesting theory, but even if I don't toggle the vent at all, they tend to die quick.
That being said, somehow the Energizer Lithiums are still going. I'm blown away.
So my Vent that has been going about 45 days now died yesterday..but all I had to do was eject the batteries and reinsert. Came right back up. I see this a lot as well.
It's almost like they use different chipset for various production runs, and some of us just get really unlucky. Keen must be aware of this, or they'd be more interested in helping.
I had to do that fairly regularly on one of my four vents when I had them. :confused:
Yeah my experience so far has been that if I don't send enough activity to drain the batteries within about a month that I have to reset the batteries like this. And even when the batteries appear fully dead if you take them out and swap the two sets with each other from left to right all the sudden there's still energy left in the batteries because they don't equally drain from each side. It's too parallel circuits for three volts. Perhaps they haven't divided up to where the left set of batteries run certain equipment and the right side run certain equipment and therefore they don't drain equally instead of it being actually wired in parallel.
Funny, the list of problems keeps growing. I just walked into a guest bedroom and the vent was cycling one per second... No idea how long, but probably less than 24 hours. HE is showing the movement as well. Nothing I have on the hub could be causing the vent to move.
Talk about extra wear. I'm sure Keen support won't care.
Keen support is simply suggesting that I factory-reset this vent that's stuck toggling back and forth. Also they reiterated that my particular vents are out of stock still--so no replacements for me.
My main supply plenum splits into 3 trunk ducts... one for each level of the house. This is not common, but something I requested when we had the house built over 10 years ago. I recently added motorized Honeywell dampers to each duct and control them with custom rules based on where I want air to go. A Zooz ZEN16 is used for the "smarts." Everything is hardwired and powered by a 24VAC transformer. It has worked great this winter and I'm looking forward to seeing how the summer season goes.
If you have access to your ducts, you should be able to do something similar. There is also a great HVAC zoning app that can help. Includes options for dampers, booster fans, etc. The documentation is great and has some really helpful info for avoiding things like freezing your AC coils and the like. I really wanted to use it but my ecobee thermostat doesn't play nice with the app.
You're absolutely correct that precise control of small zones is a challenge, especially with residential equipment. Even larger commercial systems can struggle with zones that are too small or where loads/setpoints vary widely. In some cases designers will use a mini splits (or their variable-volume commercial equivalents) to do what @Sakman mentioned. But if you understand the capabilities and limits of your equipment, it is certainly possible to optimize it and get better performance than your typical residential contractor can do for you.
So I have 6 Keen vents in the house and I have a battery life issue with only one. It seems to make constant updates to my ST hub where the others do not. I think it's the model version that's defective.
These models have no battery issue:
SV01-612-MP-1.0
SV01-610-MP-1.1
SV01-610-MP-1.0
This one sucks:
SV02-610-MP-1.3
I'll have to check what I have. They're all worthless.
How long does your 'bad' one last on a fresh set? How often do they move?
So I just removed the offending Vent from my ST Hub, held down the button on the vent hardware for a bit of time until the lights did some flashing, etc. (Sorry, I didn't pay attention to the color(s), etc.) I assume it was a sort of reset. Then I re-paired it with my ST hub. This time, the activity has calmed down. No new events were updated until I adjusted the vent % opening almost 30 minutes later. I think the batteries should last longer now. Prior to this, I was getting several event updates every minute.
I've been using lithium rechargeables on the unit. I practically "never" adjust this one. Every time I happened to want to adjust it via Alexa, I notice it's offline and the batteries were drained. If I had to guess, the batteries may last a week or two...at the most. The event history on the device showed updates hitting the ST hub a couple every minute. As mentioned in my other post, after unpairing, hardware resetting, and the re-pairing, the events have completely calmed down to only occurring when I interact with it. Also of note: I observed the battery issue whether the device was hopping straight to the hub or through my Ikea plug.
I just noticed that you are using the ST hub. That's kind of the whole thing. Hubitat has problems with various devices.
Examples please?
In my specific case I had issues with the Aeon Labs multisensors having massive battery drain, which there are endless threads on,the keen vents, and I never could get my Schlage FE599NX to pair to my c7. It's the only reason my c5 is still in service. Hubitat is great, but there are a few quirks, is all I'm saying.
FWIW, this lock has issues with other 700-series controllers.
I agree with the opinion above.
My A/C guy told me that closing vents is not a good idea for central air conditioning. Actually, several A/C technicians over the years have told me this.
The best way for more granular control is a mini split ductless system.
As a "blanket statement" that is false (that's why they make vents closable...). And the techs know that (they aren't dumb), but it is an easier/safer answer.
Whether it is harmful depends if air handler has a high pressure spillback/overpressure vent, depends on how many vents are closed vs total, do you have a variable speed blower. etc.
There are definitely circumstances where it is true, though - too many vents closed can cause too much back pressure can wreck/harm the blower, too little air flow over the coil can be harmful, etc.
So I get why some techs just say "don't close them", as the real technical answer is complicated and "it depends", which is too hard/nuanced to explain to most customers.
I think the reason most say this is that the majority of single zone HVAC systems are very basic, especially the units that are a prime target for Keen vent customers.
