Avatto 2 gang switch isn't working
I bought a few switches and the 1 gang works perfectly fine with the Zemismart driver I found here, but unfortunately I didn't manage to get the 2 gang to work.
  • endpointId: 01
  • application: 50
  • manufacturer: _TZ3000_dlp6yvs8
  • model: TS0012
Any ideas?
I have (in theory) same device, not used. Is it yours ZWSM16-2? Give me some time, I will find it and try to help you.
got mine, but it have different fingerprint than your hardware
Manufacturer:	_TZ3000_mtnpt6ws
Endpoint 01 application:	48
Endpoint 01 endpointId:	01
Endpoint 01 idAsInt:	1
Endpoint 01 inClusters:	0003,0004,0005,0006,0702,0B04,E000,E001,0000
Endpoint 01 initialized:	true
Endpoint 01 manufacturer:	_TZ3000_mtnpt6ws
Endpoint 01 model:	TS0002
Endpoint 01 outClusters:	0019,000A
Endpoint 01 profileId:	0104
Endpoint 01 stage:	4
Endpoint 02 application:	unknown
Endpoint 02 endpointId:	02
Endpoint 02 idAsInt:	2
Endpoint 02 inClusters:	0004,0005,0006
Endpoint 02 initialized:	true
Endpoint 02 manufacturer:	unknown
Endpoint 02 model:	unknown
Endpoint 02 profileId:	0104
Endpoint 02 stage:	4
Endpoint F2 application:	unknown
Endpoint F2 endpointId:	F2
Endpoint F2 idAsInt:	242
Endpoint F2 initialized:	true
Endpoint F2 manufacturer:	unknown
Endpoint F2 model:	unknown
Endpoint F2 outClusters:	0021
Endpoint F2 profileId:	A1E0
Endpoint F2 stage:	4
and it is working fine, I did not connect any leds/bulbs. But mine is detected fine, and is fully reacting (I hear "tick", when enabling/disabling channels on it) for commands. What is precisely your issue?
Did you used "initialize"?
After pairing it again a couple of times it seems to work just fine now.
It is possible. I even noticed, that some devices need to be paired quite close to the hub. They later could be placed anywhere, but initial pairing had to be done that way.
