Just switched over to the new hub (latest version) and built some basic light rules to test and start setting things up. All looks good, except that the automations dont work at sunset (lights on). If I run the rule manually, it works as expected; it just does not work at sunset. What am I missing? Thanks.
As a start I would check that you have you defined the correct time zone for your location?
If this is correct it might be worth posting your rule so that people can cast their eyes over it.
I thought about the time zone. Where do I find that setting? Thanks.
Left menu bar Settings, then Hub Details.
Found it, wrong time zone. Thanks ![]()
