Hello everyone!
I use my Hubitat to monitor water use, start a siren after 30 continuous minutes of running water, then shut the water off after 15 more minutes. I do this to prevent a holding tank from filling to overflowing should a toilet run or a faucet be left on.
The rule has worked great for multiple month. But around August 11, it started failing. The rule appears to trigger when the water starts running, but does not appear to get the message that the water use has dropped. This happens intermittently.
I control the well pump with a GE 40 Amp Switch. I have been using the community “Z-Wave Metering Switch” driver. This has required a rule to manually refresh the switch (currently configured for every two minutes) to get a power value for the well pump to use in the rule.
When I refresh the switched, I do not see the refresh info in the device “Events” table. I think I did in the past but am not sure.
In the process of researching this, I found the supported driver for “GE 40 Amp Switch.” Great to see a supported driver, but does not seem to make any difference. One interesting thing about the driver is that it has an energy report capability. However, the only thing it seems to report is line voltage.
Any suggestions for what to look at next?
Thanks!
