Hey everyone,
I'm seeing some strange (and seemingly random) delays with some automations that aren't completely making sense to me. I previously had issues with ZWave performance, which the HE team addressed in several firmware updates.
What I'm seeing now almost seems like potential Hub overload:
Downstairs Bathroom Motion (Aeon Multisensor 6) fired at:
motion active Downstairs Bathroom Motion motion is active DEVICE 2019-02-26 01:41:12.915 PM PST
Downstairs Bathroom Light (Aeon Nano Dimmer) got signal and turned on at:
switch on Downstairs Bathroom Light was turned on [digital] DEVICE digital 2019-02-26 01:41:38.320 PM PST
So, basically, it was almost 30 seconds before the light came on - this is a simple Motion Lighting - based solely on Motion, not on Lux.
For background, I only have one 'User App' installed - Other Hub Pusher to support using Classic SmartThings app mainly for my partner (she prefers that to Alexa a lot of the time). I've paired back the update time in Other Hub Pusher to 15 min, and limited what gets pushed as real time.
What's particularly challenging here is that I can't seem to establish a pattern of when this is happening. There are several times recently where I thought that that Motion Lighting wasn't working correctly, but it was likely that the delays were just so out of whack that I turned on the light manually. And then there is the norm - about 85% of the time, things work flawlessly.
So, has anyone else seen this issue, and, do you have any suggestions on logs I should be capturing to help debug this?
Thanks.
