Auto Lock Door Modes no longer work after update 2.2.3.118
I'm using the Auto Lock Door app for my front door. --found here Help. Automatically locking back door - #6 by keithcroshaw -- It had been working perfectly, I had the the timeout times set differently for different modes. After updating to 2.2.3.118 the mode setting will no longer save. Has anyone else noticed an issue with this?
I tested before the update and after the update.
I was able to select modes before the update and save, they would be selected even I returned.
After the update I was unable to save the mode selections.
Fortunately for me I don’t need mode selection but I’ll summon @bobbyD , been a while.
I feel like my test is pretty conclusive something in the update broke mode selection here.
I know 3rd party apps aren’t technically supported but maybe you can look into it Bobby.
Thanks!
Can you turn on device and app debugging for the devices and apps involved here.. And capture a log of the event?
No option for logging in the app...But here is what I have.... I don't see any mention of the mode, Seems to be ignored now.
dev:31792020-08-13 08:17:19.503 pm infoEthan's Lamp was set to 64%
app:40882020-08-13 08:17:10.477 pm debugDoor Closed
dev:31492020-08-13 08:17:10.446 pm debugparsed 'zw device: 34, command: 7105, payload: 06 00 00 FF 06 17 00 00 , isMulticast: false' to [[name:contact, value:closed, descriptionText:Z-Front Door Sensor was closed]]
dev:31492020-08-13 08:17:10.444 pm infoZ-Front Door Sensor was closed
dev:31492020-08-13 08:17:10.439 pm debugNotificationReport cmd:NotificationReport(v1AlarmType:6, v1AlarmLevel:0, reserved:0, notificationStatus:255, notificationType:6, event:23, sequence:false, eventParametersLength:0, eventParameter:[])
dev:31492020-08-13 08:17:10.248 pm debugparsed 'zw device: 34, command: 2001, payload: 00 , isMulticast: false' to null
dev:31492020-08-13 08:17:10.246 pm debugparsed 'zw device: 34, command: 2001, payload: 00 , isMulticast: false' to null
dev:31492020-08-13 08:17:10.238 pm debugBasicSet cmd:BasicSet(value:0)
dev:31492020-08-13 08:17:10.230 pm debugBasicSet cmd:BasicSet(value:0)
app:40882020-08-13 08:17:08.021 pm debugDoor open reset previous lock task...
dev:12242020-08-13 08:17:08.001 pm infoX-Basement Sensor 3 temperature is 70.24°F
dev:31492020-08-13 08:17:07.187 pm debugparsed 'zw device: 34, command: 7105, payload: 06 FF 00 FF 06 16 00 00 , isMulticast: false' to [[name:contact, value:open, descriptionText:Z-Front Door Sensor was opened]]
dev:31492020-08-13 08:17:07.185 pm infoZ-Front Door Sensor was opened
dev:31492020-08-13 08:17:07.170 pm debugparsed 'zw device: 34, command: 2001, payload: FF , isMulticast: false' to null
app:40882020-08-13 08:17:07.166 pm debugRe-arming lock in 10 minutes (600s).
app:40882020-08-13 08:17:07.164 pm debugLock lock is unlocked.
app:40882020-08-13 08:17:07.163 pm debugDoor null
dev:31492020-08-13 08:17:07.126 pm debugNotificationReport cmd:NotificationReport(v1AlarmType:6, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:6, event:22, sequence:false, eventParametersLength:0, eventParameter:[])
dev:31492020-08-13 08:17:07.123 pm debugBasicSet cmd:BasicSet(value:255)
dev:20912020-08-13 08:17:05.588 pm infoFront Door was unlocked via key or thumbturn [physical]
dev:20912020-08-13 08:17:05.583 pm debugdescMap:[raw:catchall: 0104 0101 01 01 0040 00 BABD 01 00 0000 20 01 020EFFFF0063CE901300, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BABD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[02, 0E, FF, FF, 00, 63, CE, 90, 13, 00]]
app:40882020-08-13 08:17:03.944 pm debugCancelling previous lock task...
app:40882020-08-13 08:17:03.943 pm debugLock lock is locked.
app:40882020-08-13 08:17:03.941 pm debugDoor null
dev:20912020-08-13 08:17:03.895 pm infoFront Door was locked via key or thumbturn [physical]
dev:20912020-08-13 08:17:03.890 pm debugdescMap:[raw:catchall: 0104 0101 01 01 0040 00 BABD 01 00 0000 20 01 020DFFFF0061CE901300, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BABD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[02, 0D, FF, FF, 00, 61, CE, 90, 13, 00]]
app:40882020-08-13 08:16:58.969 pm debugDoor Closed
dev:31492020-08-13 08:16:58.843 pm debugparsed 'zw device: 34, command: 7105, payload: 06 00 00 FF 06 17 00 00 , isMulticast: false' to [[name:contact, value:closed, descriptionText:Z-Front Door Sensor was closed]]
dev:31492020-08-13 08:16:58.840 pm infoZ-Front Door Sensor was closed
dev:31492020-08-13 08:16:58.830 pm debugNotificationReport cmd:NotificationReport(v1AlarmType:6, v1AlarmLevel:0, reserved:0, notificationStatus:255, notificationType:6, event:23, sequence:false, eventParametersLength:0, eventParameter:[])
dev:31492020-08-13 08:16:58.663 pm debugparsed 'zw device: 34, command: 2001, payload: 00 , isMulticast: false' to null
dev:31492020-08-13 08:16:58.659 pm debugBasicSet cmd:BasicSet(value:0)
app:40882020-08-13 08:16:56.127 pm debugDoor open reset previous lock task...
dev:31492020-08-13 08:16:56.092 pm debugparsed 'zw device: 34, command: 7105, payload: 06 FF 00 FF 06 16 00 00 , isMulticast: false' to [[name:contact, value:open, descriptionText:Z-Front Door Sensor was opened]]
dev:31492020-08-13 08:16:56.091 pm infoZ-Front Door Sensor was opened
dev:31492020-08-13 08:16:56.086 pm debugNotificationReport cmd:NotificationReport(v1AlarmType:6, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:6, event:22, sequence:false, eventParametersLength:0, eventParameter:[])
dev:31492020-08-13 08:16:55.882 pm debugparsed 'zw device: 34, command: 2001, payload: FF , isMulticast: false' to null
dev:31492020-08-13 08:16:55.876 pm debugBasicSet cmd:BasicSet(value:255)
dev:1402020-08-13 08:16:51.229 pm inforcvd: OUTPUT,11,1,0.00
dev:1342020-08-13 08:16:50.986 pm infoKitchen Overhead light was turned off
dev:1402020-08-13 08:16:50.985 pm inforcvd: OUTPUT,30,1,0.00
dev:16992020-08-13 08:16:50.966 pm infoDining Room Light was turned off
app:40882020-08-13 08:16:49.728 pm debugSettings: [minutesLater:10, lock1:Front Door, openSensor:Z-Front Door Sensor]
app:40882020-08-13 08:16:49.725 pm debugAuto Lock Door updated.
It looks like this also affects a couple of the Cobra apps that I use, Appliance running and Appliance Finished. I cannot save the option for "modes" . Something must have changed.
"as these are 'single page' apps, the 'mode' section is formatted and controlled by the platform"
@bcopeland @bobbyD
This issue remains after the last two updates/hot fixes. Any idea what changed?
Hello, from what I understand the 'mode' section is formatted and controlled by the platform OS. I'm on the lastest hubitat version (2.2.3.145) and this issue still remains.
Any update on what changed? I would like to be able to use the mode feature in these apps if possible.
@bravenel this issue is back..
@bravenel any chance you can fix the “set for specific modes” for single page apps again? I can confirm one of my custom apps is also now broken where I had modes set and now the list is empty.
@bcopeland FYI for your awareness since you were responding above. This issue appeared last year and Bruce fixed it, but now broken again.
Thanks!
It will be fixed in next release.
