My hope is that this will help someone who is struggling to pair their Z-Wave Lock to SmartThings.
Background
- Owned the August Pro since 2017 (Gen 3) lock.
- Originally paired to SmartThings before S2 was a thing.
Migration to Hubitat Attempt
I kept trying to pair this with S0 security and it would not work.
I tried pairing this to back to SmartThings (worked originally, but the pairing was back in 2018). This no longer worked trying S0 security.
At this point I knew I had to use S2 security.
Steps for Successful Pairing
- Don't bother using S0 security, you must take the S2 route or it won't work.
- Take off the faceplate of your August Lock and have this handy.
- Run Z-Wave Exclusion from Hubitat + August App.
- Run Z-Wave Inclusion from Hubitat + August App.
- Once detected, use the S2 security option from Hubitat.
- On the inside of the August Faceplate is the first 5 digits of your 'DSK' code (should be a Z-Wave sticker with a 5 digit code). Type this in and continue pairing.
Hopefully this works for someone else that may be struggling.
