I was able to discover one of my August Pro locks with little difficulty, and it appears that it is paired to the C7 hub with S2 security. However, I tested and found that the driver logs a warning and doesn't change the lock state as I expected when the lock is jammed.
When this lock is jammed, the AccessAlarmReport (zwaveAlarmType == 6) is being sent with zwaveAlarmEvent == 11.
These are triggered if you have the august keypad paired with the lock.
Side Note: There is also a longstanding bug in the August firmware that will result in these keypad events in response to the zwave lock and unlock commands, instead of the usual zwaveAlarmEvent:3 and zwaveAlarmEvent:4 in some scenarios.
