Did you end up getting any, Nic? I can't figure out how it works from the pics.
Works on ball valve taps. Basically turns it 90 degrees. Got it from AliExpress awhile back for around the same price but kogan actually includes the power supply.
That's right, it works on a ball valve which I had to have fitted to the water main as I had the nasty old standard screw valve.
It works great using the inbuilt "Sinope water valve" driver.
I have it powered off a 12v 1.3AH battery charged off a small solar panel at the end of the drive out near the street,
I replaced the double GPO in my power board box with a ikuu Zigbee one and despite the power box being made of gal-Iron they all connect up to the hub just fine.
The hardest thing was getting a plumber to do such a small job.
Thanks Nic. We're about to build a new house so I'm scoping for ideas for the build. It's the ultimate maker project. I get to scope whatever the hell I like (as long as I can afford it).
Did you ever think about using a micro turbine to power the battery from the water flow itself?
No however that sounds interesting.
Iād be concerned that thereād not be enough regular flow of water from the mains to charge the 12v battery enough that Iām using, connected to the motorized valve & controller.
Seems like a good deal for the GU10, bear in mind this is a twin pack ambient white. $2.50 more than the equivalent Tradfri at the moment.
**** Deal now over was $45.64 for a twin pack, back to $71.34 now, keep an eye out though as regularly drops, this is the lost I have got them though ****
Cheers
Steve
I found this as well. I spent ages trying to troubleshoot my routine
Super price for local stock for a HE C7 here. $179 with free post.
Looks like a decent zigbee filament bulb deal; I wonder whether it will work with HE.
