I am trying to setup an association between:
- Zooz ZEN27
- Fibaro RGRBBWM-441 v2.5
My goal is to control a single channel of the RGBW dimmer with the ZEN27 such that the RGBW will "track" the dimmer with little or no delay.
I talked to Zooz support and they said it could be done but both devices needed to be paired without security.
I read through the Inovelli Association tool and from what I gather the below code (with modifications for the capability of the RGBW) in the Fibaro RGBW Driver.
Does the built in Fibaro RGBW driver have such code included?
I'm not sure if the ZEN27 needs to have similar code. Does the current driver have such code?
Also, am I on the right track? Or is there a better approach?
John
def cmds = []
cmds << zwave.associationV2.associationSet(groupingIdentifier: 1, nodeId: zwaveHubNodeId)
cmds << zwave.associationV2.associationGet(groupingIdentifier: 1)
cmds << zwave.configurationV1.configurationSet(configurationValue: [ledIndicator? ledIndicator.toInteger() : 1], parameterNumber: 1, size: 1)
cmds << zwave.configurationV1.configurationGet(parameterNumber: 1)
cmds << zwave.configurationV1.configurationSet(configurationValue: autoOff!=null? integer2Cmd(autoOff.toInteger(), 2) : integer2Cmd(0,2), parameterNumber: 2, size: 2)
cmds << zwave.configurationV1.configurationGet(parameterNumber: 2)
cmds << zwave.configurationV1.configurationGet(parameterNumber: 3)
cmds << zwave.configurationV1.configurationGet(parameterNumber: 4)
commands(cmds)
