What is the best way to say have a group of lights throughout the house (accent lights in this case) and have them be turned on and off as one... I somewhat often change this grouping and would like to not have to update every rule that uses them each time.
If some (or all) of them are zigbee bulbs directly paired to Hubitat, make sure you turn on Zigbee Group Messaging when you create your group. That permits a single command to control all zigbee bulbs within the group - so it is much faster and pretty much eliminates "pop-corning".
