They are not on the Compatible Devices list. I have a door sensor from them and it does not seem to work using the Generic driver.
The device comes up as lumi.sensor_magnet.aq2
Officially no, as you found. However, a search for your model number will reveal a few community derivers you can try if you want:
https://community.hubitat.com/search?q=lumi.sensor_magnet.aq2
Also, one of those search results will be a thread about Xiaomi/Aqara devices and how to keep them paired. This is a good read, as most are not standard Zigbee devices and are prone to "falling off" your network if you aren't careful about how you build it.
This topic has been marked solved by the community and subsequently closed.
