I just tested this out on one of my ST sensors. I'm mainly using it for temp monitoring at the moment, but it's mounted on the wall at one side of a large foyer. I walked along the other wall (about 9-10m away), and it detected me easily. I'm not sure why you would be having issues at just 15ft away.
One thing, in case you don't already know this: PIR motion sensors detect best when something moves across their field of view, rather than towards/away from the sensor. Could this be a factor in your sensor's performance?
I have several Sylvania motion sensors and get at least 20 feet in range. They are much more sensitive than my Iris V2.
I have a couple ring V1 motion sensors that will pick up a rabbit at 30 feet (mounted under the eves), but they take about a second to wake up and register.
Wow. I don't get that from this one unfortunately.
I may look to see if they are all the same as I have 3x of them in the house but only rely on one which is the one in that room so haven't checked the others.
Yeah this really can affect response / detection times. [quote="jason-lane, post:42, topic:25890"]
[/quote]
I wonder if the orientation (which way up) matters for these sensors. They don't have such an obvious "up" when looking at them from the front but some sensors seem to be designed to look somewhat downwards, as they're usually mounted higher up on a wall. I have mine mounted so that the text on the label on the back is the right way up.
Curios, Honestly just powered up my Hubitat for the first time yesterday.. Added the Lutron Smart Pro Hub, multiple lights, and Homeseer door contacts. When I tried to pair the HS-MS100+ I'm not having any luck. When Pairing Secure Inclusion Mode, it shows up and gives me "8" sub items, but will not change current start on screen. If i remember correctly it pairs under "Ring Sensor" I ran exclusion, and tried with Non Secure Inclusion, shows up as Generic, but doesn't seem to do anything at all. Just wondering what Pair method you used, and if you could point me int he right direction.
I would try excluding it again and reset it. Include it normally as close to the hub as possible, and check to see if it is using the generic z-wave motion sensor driver. I don't use Hubitat for devices anymore so maybe someone who does can chime in.
In general, most users report that Zigbee motion sensors are faster than Z-Wave motion sensors. The SmartThings (2018 and the probably identical Aeon Zigbee model) sensors are pretty fast for me, so maybe you got a dud or are dealing with a hub or network issue.
Historically, I've been a fan of anything OEMed by Centralite, including the beloved Iris v2 sensors, but those are long out of production and the only thing I'm aware of that they have in stock now is their own Micro Motion Sensor. It's fast for me, but it uses a coin cell battery rather than one of the cylindrical sizes, so I'm not sure how life will compare (but even a bit less than multiple years on my Iris v2 sensors would be OK with me!). For some recent community favorites, you may wish to check out this thread:
Zigbee will almost always (always in my experience) be faster than Z-Wave
Iris V2 and V3 are my speed champs. You can still find the Iris V3 on eBay on and off, and they use cylindrical batteries and have long life. They are also small - V2 is very small, V3 a little larger but also reports humidity. Both report temperature.
Centralite makes great gear, and the one Robert referred to does motion and temp. Also looks good and is relatively small.
There is also the SONOFF, but IMHO it's pretty darn ugly, and did not pass the WAF test in our home. (Says Switch below in the link but the page it goes to has the motion sensor.)
The Hue sensors are probably a good as any other and better than most. Even "in production" models may be hard to come by right now... especially the more desirable ones like you are asking for.
I have several of the Hue outdoor. They respond very quickly, have great range, and the battery life is frankly unbelievable. According to Hubitat, I installed my first one over my garage door in November 2019. Last week it stopped reporting events, and despite the battery reporting 100%, I thought maybe it had finally died. I opened it up and tested the 2AA batteries, and they are still VERY strong. I re-paired it with the controller, and it is again working like a champ. This is the ONLY problem I've ever had with any of the 3 of them I have had for over 2 years now. The temp and lux reporting work well, and the lux comes in handy for turning morning and evening automations on and off. I have one over my front door, and one in the garage. I could have gotten a cheaper sensor for the garage, but then might have needed 2 to reachthe far side of the room. The range on the Hue outdoor easily covers the whole area.
I'm thinking I should replace an older zwave motion sensor which is slow, not entirely reliable, and requires more frequent battery changes. I just haven't bothered because that one is in a low priority area.
