Seeing posts re dashboards w hub variables, I tried adding vars w&w/o connectors to an older DB & new. They don't show up when adding a tile. They've been authorized in DB.
When loadin w DB, a popup says loading vars
Are you using a browser or the mobile app? If the mobile app try using the browser instead.
Chrome broswer, running 2.3.0.112
Thx
Best bet then may to be trying to access using a link off the child dashboard app to the dashboard when trying to add them.
What happens if you click the Tile Type and select Variables from the drop down?
That works... Is this documented anywhere ? BTW this works w & w/o connector
BTW seems DBs take longer to load than previous releases. Due to pop up re loading vars ??
