Aquarium Light
Chances are there is not an easy way to do any integration. With a Bluetooth light there is no API or network access that a Hubitat driver could try to send commands through.
Doing a little research on it, the WiFi version seems to use the Magic Home Pro app... which is something that has an integration created for Hubitat (although I do not know if it would support an aquarium light specifically).
But for the Bluetooth... maybe you can reach out to AquaticLife and see if they can recommend some sort of Bluetooth-WiFi bridge device or alternative?
