Aqara zigbee light switch
Hi Amaduhi,
I edited my previous post - that driver is for another Aqara device.
Your device should be this one :
For it - try this driver (just updated ver. 2.0.7 2024-05-11, timeStamp 2024/05/11 9:21 PM)
https://raw.githubusercontent.com/kkossev/hubitat-Markus-Li-fork/release/drivers/expanded/zigbee-aqara-wall-switch-expanded.groovy
Click on the Initialize button after updating the driver.
Dear Krassimir, I can confirm the driver is perfectly working with Aquara E1 switch double rocker with neutral, including decoupled ''disconnect'' mode. Thank you very much, now I can start thinking on smart bulbs in decoupled mode.
I am glad it worked! Let us know how the decoupled 'smart bulb' mode works for you,
@fdelima your switch should also be supported in the same driver.
Aqara switches are typically of a much better quality than Tuya (90% of the unknown brands sold on Amazon US are actually Tuya!),
I wouldn't worry about safety (except if a UL/ETL certification is an absolute MUST for your property insurance - here we don't have such requirements in the EU).
Hi kkossev,
Do you have a recommendation between these two options for using the Aqara single pole no neutral required US version switch?
(1) A driver in Hubitat that will allow for operation with direct connection to Hubitat? If this is your pick do you suggest a driver?
(2) Join the switches via my Aqara hub and then connect the Aqara hub to Hubitat via Matter?
As always thank you for all your help.
Hi Amaduhl,
Thank you. It is encouraging to see this information and your later posts. I am glad you have got them working as you need.
