I have had an AQARA U200 lock for a couple years that i could never get full functionality from. I bought an aqara H3 hub to add as a matter bridge so i can have that functionality with the aqara app and bring into HE. I have the H3 matter hub setup in HE but still can't get the U200 to show/pair with HE. I have used a secondary matter code from the aqara app to add but fails.
What platform version are you running?
Platform Version:
2.4.2.129
I'm running .131, but there haven't been any changes to the generic matter lock driver since 127 when the 200 fingerprint was added.
I remember there was some funk in getting it added, after getting the code from the M3 bridge did you push the set button on the lock?, then init matter discovery on Hubitat?
I think that's what I had to do, but to be honest I don't remember exactly.
Yes, i did it just like that. I have done factory reset on the lock a couple of times and then tried it. I then setup in the aqara app then get matter code and try to pair in HE.
I also have a new aqara mmwave presence senor FP1E, but it doesn't work correctly and shows it as a 3 button sensor. I am using the aqara sensor that shows in the list but it must not be the right driver for it.
While I have your attention. I have a Bond bridge that i recently realized HE has a integration for. Well, i have a ceiling fans and a fireplace that are setup on the Bond bridge and work well thru Alexa. Tried the HE bond integration but it does not show the devices to setup?? I was hoping to use a more elaborate rule for the fans thru HE.
Aside from zigbee and zwave devices i have not been able to get anything else to integrate with HE! I have tried a couple community/custom drivers when i first got my Hubitat c8 but couldn't get to work. Sorry, i am venting. I have tried following step by step videos to setup wifi devies but they are either out of date or didn't work for me either. I am really frustrated at this point!
Thanks for your time though i really do appreciate it.
I'll re-add my U200, but now that I think of it I don't believe I used the code from the M3, have you tried the matter code on the lock?
I don't know the issue with the bond bridge, I suspect it has something to do with the actual device on the bond bridge. Similar to other issues your facing with devices, it would be nice to know what devices you're having issues with and whether they exist on our compatibility list or not.
Currently, Hunter ceiling fans with remote, The aqara u200 lock and the aqara mmwave presence senor FP1e as i mentioned previously.
Yes, I am pretty sure I tried the matter sticker on the lock itself. There was something about the lock only pairing with one matter code so maybe I didn't try it? I will try again.
Hey, I got the bond integration to work!!
I have had this bond bridge for a few years now. A couple years back updated to a mesh network and left the old 2.4 network intact. The bond bridge was set to the old network! And it was several firmware updates behind.
Yeah, a win!
