Aqara - Matter Bridge stopped working
I noticed today that my matter bridged device from Hubitat to my Aqara M3 are no longer working. I see the following errors. I already tried removing the bridge and adding it again. I am using the built-in Matter bridge in Hubitat. I am on the latest release software. When I did that I got one set of reports then only the following after that set: Here is the log:
**dev:1953**2026-06-30 11:42:41.745
debug
getComponentSubscriptions:[[ep:0x47, cluster:0x0006, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.741
debug
getComponentSubscriptions:[[ep:0x46, cluster:0x0006, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.736
debug
**dev:1953**2026-06-30 11:42:41.731
debug
**dev:1953**2026-06-30 11:42:41.726
debug
getComponentSubscriptions:[[ep:0x59, cluster:0x0006, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.721
debug
getComponentSubscriptions:[[ep:0x5C, cluster:0x0006, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.715
debug
**dev:1953**2026-06-30 11:42:41.710
debug
getComponentSubscriptions:[[ep:0x50, cluster:0x0006, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.705
debug
getComponentSubscriptions:[[ep:0x4F, cluster:0x0006, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.700
debug
**dev:1953**2026-06-30 11:42:41.694
debug
**dev:1953**2026-06-30 11:42:41.689
debug
getComponentSubscriptions:[[ep:0x31, cluster:0x0406, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.684
debug
getComponentSubscriptions:[[ep:0x5A, cluster:0x0406, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.679
debug
getComponentSubscriptions:[[ep:0x38, cluster:0x0405, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.674
debug
getComponentSubscriptions:[[ep:0x37, cluster:0x0402, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.668
debug
**dev:1953**2026-06-30 11:42:41.662
debug
**dev:1953**2026-06-30 11:42:41.657
debug
getComponentSubscriptions:[[ep:0x67, cluster:0x0405, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.652
debug
getComponentSubscriptions:[[ep:0x66, cluster:0x0402, attr:0x0000]]
**dev:1953**2026-06-30 11:42:41.647
debug
**dev:1953**2026-06-30 11:42:41.641
debug
**dev:1953**2026-06-30 11:42:41.548
debug
Endpoints found: [[endpointId:65, label:Aqara Temp/Humidity Sensor, inClusters:001D,002F,0039], [endpointId:66, inClusters:001D,0003,0402, label:Aqara Temp/Humidity Sensor], [endpointId:67, inClusters:001D,0003,0405, label:Aqara Temp/Humidity Sensor], [endpointId:66, inClusters:001D,0003,0402, label:Aqara Temp/Humidity Sensor], [endpointId:67, inClusters:001D,0003,0405, label:Aqara Temp/Humidity Sensor], [endpointId:36, label:Aqara Temp/Humidity Sensor, inClusters:001D,002F,0039], [endpointId:37, inClusters:001D,0003,0402, label:Aqara Temp/Humidity Sensor], [endpointId:38, inClusters:001D,0003,0405, label:Aqara Temp/Humidity Sensor], [endpointId:37, inClusters:001D,0003,0402, label:Aqara Temp/Humidity Sensor], [endpointId:38, inClusters:001D,0003,0405, label:Aqara Temp/Humidity Sensor], [endpointId:5A, label:Aqara Motion Sensor P1, inClusters:001D,0003,002F,0039,0406], [endpointId:31, label:Aqara Motion Sensor P1, inClusters:001D,0003,002F,0039,0406], [endpointId:50, inClusters:001D,0003,0006, label:Aqara Wall Switch EU], [endpointId:4E, label:Aqara Wall Switch EU, inClusters:001D,0039], [endpointId:4F, inClusters:001D,0003,0006, label:Aqara Wall Switch EU], [endpointId:4F, inClusters:001D,0003,0006, label:Aqara Wall Switch EU], [endpointId:50, inClusters:001D,0003,0006, label:Aqara Wall Switch EU], [endpointId:62, label:Aqara Wireless Remote Switch, inClusters:001D,002F,0039], [endpointId:63, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:64, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:63, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:64, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:5B, label:Aqara Light Switch H2 EU, inClusters:001D,0039,0090,0091,009C], [endpointId:5C, inClusters:001D,0003,0006, label:Aqara Light Switch H2 EU], [endpointId:5D, inClusters:001D,0003,003B, label:Aqara Light Switch H2 EU], [endpointId:5E, inClusters:001D,0003,003B, label:Aqara Light Switch H2 EU], [endpointId:5C, inClusters:001D,0003,0006, label:Aqara Light Switch H2 EU], [endpointId:5D, inClusters:001D,0003,003B, label:Aqara Light Switch H2 EU], [endpointId:5E, inClusters:001D,0003,003B, label:Aqara Light Switch H2 EU], [endpointId:59, label:Aqara Smart Plug EU, inClusters:001D,0003,0006,0039,0090,0091,009C], [endpointId:54, label:Aqara Wireless Remote Switch, inClusters:001D,002F,0039], [endpointId:55, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:56, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:55, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:56, inClusters:001D,0003,003B, label:Aqara Wireless Remote Switch], [endpointId:45, label:Aqara Dual Relay Module T2, inClusters:001D,0039,0090,0091,009C], [endpointId:46, inClusters:001D,0003,0006, label:Aqara Dual Relay Module T2], [endpointId:47, inClusters:001D,0003,0006, label:Aqara Dual Relay Module T2], [endpointId:46, inClusters:001D,0003,0006, label:Aqara Dual Relay Module T2], [endpointId:47, inClusters:001D,0003,0006, label:Aqara Dual Relay Module T2]]
I also have a aqara M100 and a G3 camera. Both of those devices are reporting their child device status correctly.
I see this error in the matter log: 2026-06-30 12:02:37.033
EM
[2714:2905] >>> [E:63563r S:38415 M:265667759] (S) Msg RX from 1:0000000000000BE5 [8F5F] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:100)
[1782817246.972] [2714:2905] [DIS] OperationalSessionSetup[1:0000000000000BDC]: operational discovery failed: src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:124: CHIP Error 0x00000032: Timeout
Exception in thread "CHIP Device Controller IO Thread" java.rmi.NoSuchObjectException: no such object in table
at java.rmi/sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(Unknown Source)
at java.rmi/sun.rmi.transport.StreamRemoteCall.executeCall(Unknown Source)
at java.rmi/sun.rmi.server.UnicastRef.invoke(Unknown Source)
at java.rmi/java.rmi.server.RemoteObjectInvocationHandler.invokeRemoteMethod(Unknown Source)
at java.rmi/java.rmi.server.RemoteObjectInvocationHandler.invoke(Unknown Source)
at com.sun.proxy.$Proxy22.onConnectionFailure(Unknown Source)
