I've re-paired it, and now it works! Thanks for advice!
Iโve added IKEA repeaters to my network to help keep the cube paired. Before it would only stay connected for a day or two. After adding a repeater in the same room as the cube it works very reliably. Iโve used it on my C-4 and C-7. Hoping after I migrate to the C-8 I wonโt need the repeater anymore since it has a newer zigbee chip.
Hubitat is constantly loosing the cube:
[dev:252](http://192.168.86.249/logs?tab=past&deviceId=252#)2023-03-29 09:45:23.027[warn](http://192.168.86.249/logs?tab=past&deviceId=252#)Event interval INCORRECT, recovery mode (Normal) ACTIVE! If this is shown every hour for the same device and doesn't go away after three times, the device has probably fallen off and require a quick press of the reset button or possibly even re-pairing. It MAY also return within 24 hours, so patience MIGHT pay off.
[dev:252](http://192.168.86.249/logs?tab=past&deviceId=252#)2023-03-29 09:45:23.025[warn](http://192.168.86.249/logs?tab=past&deviceId=252#)One or several EXPECTED checkin events have been missed! Something MIGHT be wrong with the mesh for this device. Minutes since last checkin: 1109 (maximum expected 90)
