Aqara cube help
Guys, I have an Aqara cube on hubitat with this Xiaomi Mi Cube Controller drive but I don't know how to configure it, could someone help me?
Thanks friend, it worked with this drive you indicated.
Hi,
I just got an Aqara Cube and connected it to my Hubitat using the above driver. Everything is working perfectly with one exception. I'm not seeing any events when I knock on the cube. I have tried simply knocking on it with my knuckles and lifting the cube up and putting it down forcibly on a hard surface. Any ideas would be welcome.
Thanks in advance for the help
Hi jbasen. Did you ever figure out the knocking? I just got one and have the same as you.
The only actions I have are
90 flip
180 flip
push/slide
shake
rotate left
rotate right
Alan
Hi, I just got one. where do I get the driver from??
I can't remember off hand but just do a search in the forum and you'll find it.
Same boat here. I have the cube and I can get HE to recognize it. I have tried the Xiaomi driver and the Zigbee - aqara cube driver. Im not sure how to get it to control lights. I installed the cube companion and set it up but it still doesnt do anything.
Lost.
I'm not familiar with the cube companion. I use the built in "Button Controllers" app. If you send a command from the device page, does it work?
You can try this old but still functioning driver.
https://raw.githubusercontent.com/markus-li/Hubitat/development/drivers/expanded/zigbee-aqara-cube-expanded.groovy
For me it's a quick double knock seems to work.
Each action (e.g. Flip, shake, etc) will trigger a button. You can then run actions from those button presses.
Got it going in the end. I initially hit the device twice but then realised I needed to pick it up and knock it down twice.
I have to wake it up but it does seem to be working now. I am opening up the log to learn the moves and the button number in order to use it with button manager.
Thank you for your help.
Thank you. That was the driver that I had installed and it didnt seem to be doing anything. I guess I have to wake it up before it go goes.
Randy.
Thank you all for your help. I have it communicating and now its just a matter of setting up the button manager to do the rest.
Thanks again.
Randy.
