Hello,
Does anyone use the Aqara button? If so, do I need the Aqara hub to accompany it?
Hello,
There are several different models of Aqara (Xiaomi) buttons. Which one is yours?
It must be paired directly to your HE hub as a Zigbee device. Then, depending on the model, it may be supported natively by HE inbuilt drivers, or you may need to use a community driver.
It's the "wireless mini switch" . WXKG11LM. I tried to pair as a zigabee device, and directly as Aqara button with no luck.
I joined one to a C-8 Pro on the first attempt (with the Aqara Zigbee Mini Switch driver). No issues in operation. Perhaps a factory reset on the switch and another attempt.
This is exactly the Aqara button model that is now supported natively in Hubitat.
Pairing some of the Aqara battery-powered devices may require several attempts... Do you see the LED flashing three times while the pairing button is pushed down for 5 or more seconds? Try pairing close to you hub.
Thank you! I needed to go closer to the hub.
Hello,
I purchased an Aqara wireless mini switch model WXKG11LM. I am unable to pair with Hubitat C-8, I have the mini switch on the top of the Hubitat but still not pairing.
Do I need to have a special drivers installed?
I reached out to Aqara support and they said Aqara hub is required, I thought I could pair any Zigbee device with Hubitat.
Thank you for any help.
