I originally set up a rule to set mode to 'jour' (day in French) between two times: sunrise and sunset.
I did some testing, which involved at some point setting an offset of -13h (or -780 minutes) on sunset time.
Finally I decided that using a triggered rule would be a better idea and converted this rule into a triggered rule.
Now the triggered rule has in its settings obsolete data from the previous non-triggered rule that it was converted from. This data is invisible in the rule edit forms, but it is used behind the scene to affect rule behavior.
This morning, I'm in my living room and I see a light that I keep ON during the day coming ON at 7:19. I wondered what could have triggered that event and checked my rules. I see in the rule data that sunset with an offset of -780 minutes is still there (it shouldn't be as I changed my trigger events to a single one: "at 8:00am" after learning that there's a bug related to sunrise), and it just so happens that 7:19 is exactly the sunset time from 3 days ago, minus the offset.
This data is still used to trigger the rule, as can be seen in the list of scheduled jobs. It is invisible in the forms, so the user has no idea that it will be executed.
Here's the data for this rule:
Settings
Name Type Value
actSubTypeTrue.1 | enum | Set Mode |
actTypeTrue.1 | enum | Set Mode or Global Variables, Push Buttons |
atSunriseOffset3 | number | 0 |
atSunsetOffset4 | number | -780 |
atTime5 | time | 08:00 |
cond | enum | Lock mode is off |
ending1 | enum | Sunset |
endSunsetOffset1 | number | -30 |
logging | bool | true |
modes2 | enum | ["3"] |
modes3 | enum | ["1"] |
modes4 | enum | ["33","1","3","2"] |
modes5 | enum | ["4"] |
modesX2 | enum | ["1"] |
modeTrue.1 | enum | 1 |
origLabel | text | Jour |
rCapab5 | enum | Mode |
rCapab7 | enum | Switch |
rDev7 | capability.switch | Lock mode |
RelrDev6 | enum | = |
starting1 | enum | Sunrise |
startSunriseOffset1 | number | 0 |
state7 | enum | off |
tCapab5 | enum | Certain Time |
time1 | enum | Sunrise |
time3 | enum | Sunrise |
time4 | enum | Sunset |
time5 | enum | A specific time |
Event Subscriptions
No Event Subscriptions are set.
Application State
Name Value
actCondNdx | -1 |
actionDone | true |
actionListTrue | [1] |
actionsTrue | {1={wait=, modes={}, method=getSetMode, cond=0}} |
actLabelIndent | |
actNdx | 2 |
cancelList | [] |
cancelListPend | [] |
capabActDone | false |
capabDone | true |
capabsfalse | {8.false={}, 7.false=Lock mode is off, 5.false=Mode is Absent} |
capabstrue | {6.true={}, 5.true=When time is 08:00} |
certainTimes | [] |
condOper | oper |
convertedFromRule | true |
cstCmds | [] |
editCondIf | |
eraseRule | false |
eval | [NOT, 5, AND, 7] |
firstR | true |
formerState | modeLock |
globVars | {modeLock={val=false, type=Boolean}, dimLevel={val=100, type=Number}} |
hasAll | false |
hasCondition | false |
hasDevice | |
hasElse | false |
howMany | 34 |
howManyT | 3 |
inIf | false |
inRepeat | false |
installedCapabs | [Telnet, Polling, HealthCheck, Battery, Outlet, Indicator, Initialize, WaterSensor, SwitchLevel, Switch, ChangeLevel, Configuration, Light, Actuator, Sensor, Refresh] |
isExpert | false |
lastCodes | {} |
lastEvtDate | 05/19/2019 |
lastEvtName | Trigger |
lastEvtTime | 07:19 |
lastEvtValue | |
ndx.false | 8 |
ndx.true | 6 |
paramNdx | 1 |
paramsDone | false |
parenLev | 0 |
parens | 0 |
private | true |
repeating | {} |
ruleType | tule |
skipIfActionsFalse | false |
skipIfActionsTrue | false |
skipRepeatActionsFalse | false |
skipRepeatActionsTrue | false |
subscribedVariables | [] |
success | true |
token | 4 |
varUseList | {} |
wasEndSR | false |
Scheduled Jobs
Handler Next Run Time Prev Run Time Status Schedule
allHandlerT | 2019-05-20 07:19:00 EDT | 2019-05-19 07:19:00 EDT | PENDING | 0 19 7 * * ? |
Now I returned to the rule edit screen and clicked 'done with trigger events' and then 'done with triggered rule'. The data now shows the next scheduled job at the right time (8am tomorrow).
I suspect that after it executes at 8am tomorrow, the next trigger time might be set to 7:19am again. We'll see. In any event, something is wrong when the data we enter and see displayed is not the data used to trigger events...
