App type with namespace: hubitat and name: Rule-5.1 has parent type that does not match current app
I too am having this issue. I have two C-7 hubs, a new one I'm attempting to setup from scratch and another one I've had running for 3 years. Both are running on version 2.3.6.146, however only one being setup from scratch is having this problem with Rule Machine.
@bobbyD is this issue fixed in the current beta version? Or is there any other fix?
Not sure if it is fixed. I'll check with @gopher.ny in the morning, or he may chime in here, because I tagged him :slight_smile:
UPDATE: this issue has been fixed in the current beta. Anyone having this problem, please send me your hub ID or MAC address in a private message and will enroll the hub in the beta to correct the problem.
Hi, I am also having this issue. I am trying to set up a new C-7 hub with Rule Machine but keep getting the Error 404.
Have you updated the hub firmware to 2.3.7? I think the issue was fixed.
Upon updating to 2.3.7.143 I find the issue is fixed on my new C7!
I am getting this error on a C-7 with platform version 2.3.8. Was there a regression?
I just set up a new to me C7 hub, running 2.3.8.123 and I am getting this same error. Has a fix been released?
I am also getting the same issue on my C7 running 2.3.8 as well.
@bobbyD I just fired up a C7 that was on the shelf for a few years. I am running into this 404 error rule machine when I click to create my first rule. I am on 2.3.8.140. I'm not sure how to private message you, might be because I'm a new user here. Is this supposed to be fixed now?
I played around with a bunch of different versions. Rule Machine works in 2.3.7.146. But not 2.3.8.
I downgraded by downloading 2.3.7 using the following URL: http://[your hub ip]/hub/advanced/downloadPlatform/237. Wait for it to download, the page will seem like its not doing anything then it will flip to success. Apply the downgrade by going to http://[your hub ip]:8081. Click on Restore Previous Version then select the 2.3.7 version. Apply it. You may need to hard power cycle the hub if it doesn't come back up itself after awhile (10 minutes). I noticed it removed all my devices when I downgraded, so use at your own risk.
You will need to join the owners group to link to threads and post screenshots and PM other community members:
https://community.hubitat.com/g/owners
Hi BobbyD,
i also have this problem on my C7. Is it possible to fix this for me
Could you please try the following:
* replace"hubs.ip.address.here" with your hub's IP address
