Hi There, i have succesfully created control for my Panasonic heatpump nz25-vke which Can be controlled via API through the Panasonic Comfort Cloud...
I have done This by making the post requests in WebCore connected to virtuel button
However, i would like to create a real app / driver for Hubitat...
Since there is a lot of Logic stored in the webcore Code for this to work as intended...
Where to start ?
The post strings are fairly simple, so it would need and app to create the user and password for tolken, and create an aircondition device, which exposes heat/Cooling level, fan level, swing, mode...
Perhaps there already is some driver i Can rewrite?
Hi @diondp I'm trying to create the POST queries for ComfortCloud like you have posted. I am using ST and not Hubitat, but this should make no difference? Could you please post a copy of your WebCore piston so I can make it working for me? Takk!
please make sure that you have a secondary login for the ComfortCloud, otherwise this script will log you out every time from the normal ComfortCloud (thats just the way they handle Tokens)
I have one which i use for my comfortcloud, and a secondary which i then use for this WebCore piston... then it works without any problems
note this piston will fetch a new Token at every run, but this is just so you can see a working example... i have made a seperate piston to refresh the token once every 4 hours or so... and update it to a global var in WebCore
the DeviceGuid is also fetched at every run, but in my experience this is static, so once fetched, you can just hardcode that part (everything is posted to the log and variables in my piston)
replace the login and password with your own values, and see the magic (just run the piston by pressing "Test"), change the on_off_status to 0 and runt "Test" again to turn off the device.
you would make a trigger on the last "POST" part to trigger the aircondition.. it could be a button, or a seperate piston... i have made som Variables which you can change... temperature, mode (heating/cooling) and operate (on/off), fanspeed 1-5
operation_mode: 2 = Cooling, 3 = Heating.
the other variables shouldnt be touched (aircon:_token, and deviceGuid is automatically updated by the JSON request)
Thank you so much for your help @diondp However I cannot seem to get this to work. I have imported your Piston and added my secondary login for ComfortCloud with password. I have been using this same login and password before and know it is working.
When I test the piston I see the deviceGuid is missing in the log. Attached a picture of the logfile panasonic_aircon_log|690x397
Hope you can help,
PS: er du forresten dansk? Jeg er norsk - jeg kan også sende deg mitt Panasonic brukernavn og passord for innlogging om du trenger dette for å teste. Send meg en PM
Also I should mention this. When importing your piston I get promted to insert 3 different URLs. Maybe this is the reason why it's not working t56h_import|690x319
I've just installed two Panasonic units in my house that I can control via the comfort cloud app - this sounds like it might work. How did it go in the end, everything work out ok?
I had next to no luck unfortunately! I saw that home assistant crowd has theirs working. Wonder if we could use that and convert it to groovy... Probably not now I think about it
i did not have much time lately as i am very busy at work, and at home with small children....
i have the aircondition working by webcore through some json webcalls to the comfortcloud api, i have little to no experience in groovy, but i suspect it could be fairly easy to manage if there is an example guide with a http call in some driver...
Any news regarding this, I have also similar Panasonic heat pump and considering investing the hubitat platform but it would be great if this would work.
Hi there, no i didnt proceed with this APP... Panasonic changes their API connection way to often to a new version which results in too much support updating that app constantly...
I personally bought a Broadlink RM3 IR blaster and used this instead for controlling the Aircon which works perfectly.
so you can control it by some other IR blaster... Sensibo sky etc. which can be controlled by Hubitat.
If i had the time I would have created the App for it, but i had some Projectors, A/V Recievers and other stuff only being controlled by IR, so i took that route instead for more flexibility
