I'm subscribed to remote admin service. When switching on or off my local network where my hub is, the iOS app does not automatically (or at any point) switch between connection modes. It requires me to force close my app and reopen in order for the app to connect using the correct method. And as expected and as shown in image 2 below, when not on network it hangs and eventually times out trying to find my hub at the local IP address. Not sure if this is a bug or a capability that needs to be added. Seems simple enough to detect network type and adjust, or at a minimum when remote, quickly timeout when hub is not found and revert to remote access. Thank you!
Instead of closing it I just click on registered hubs then I can open local or remote. But agree network switching should work better
+1 for better detection and switching
Thanks, I forgot about being able to do it there. That does make it less painful.
