jebbett
October 29, 2022, 10:27am
1
Hi, I can't find an obvious answer so hoping someone can help..
Currently I have plex sending webhooks requests to the below in my setup:
http://192.168.1.123/apps/api/69/pwh?access_token=[token]
However I have a user that has asked if they can use the same app via a cloud instance of plex, which would mean I'd need a cloud Hubitat endpoint, I see the maker API supports devices via this method, but I don't see anything for apps?
If there is a solution do I also need a subscription?
Any help would be appreciated!
jebbett
October 29, 2022, 10:40am
2
Figured it out by butchering the API info in the Maker API app:
https://cloud.hubitat.com/api/[HUBID]/apps/69/pwh?access_token=[TOKEN]
I'll leave this here for anyone else having a similar problem in the future!
Just to further abstract your path:
https://cloud.hubitat.com/api/[HUBID]/apps/[APP.ID]/[Mapped_path_in_App]?access_token=[TOKEN]
jebbett
October 29, 2022, 10:57am
4
Thanks and everything prior to mapped_path_in_app is retrievable via getFullApiServerUrl() which is nice and easy!
system
Closed
October 29, 2023, 10:58am
5
