is there such an api?
thanks.
thanks.
I don’t think there is one officially.
I’ve just written one though that works for me. I’m using the hub ID. SmartThings hub ID is a long GUID type string whereas Hubitat returned “1” so I just check for the length of the hub Id.
if (location.hubs[0].id.toString().length() > 5) { state.hubtype = "SMARTTHINGS" } else { state.hubtype = "HUBITAT" }
After running this, you can check state.hubtype
throughout your code to see which hub you are running on. I’ll be doing this so I can work around incompatibilities and have one code base for BigTalker on both platforms.
the hub id is a Long in Hubitat not a String, that is why you are getting an exception.
you should be able to do this: location.hubs[0].id.toString().length() > 5
Fantastic that works. I'll edit my original post to show this (which simplifies it to 1 line of code:
You could also wrap it up in a function and call that function when you need it.
def getHubType(){
if (location.hubs[0].id.toString().length() > 5) { return "SMARTTHINGS" } else { return "HUBITAT" }
Then when needed just call your getHubType function.
I’ll do this in my initialize() function to set a variable for use throughout my code:
state.hubType = getHubType()
then throughout the code where there are differences in how you call a command or do something,
if (state.hubType == "HUBITAT") {
//Do some Hubitat stuff
} else {
//Do some non-Hubitat stuff
If you didn’t want to store it in a state variable, just use what’s returned from the function, such as:
if (getHubType() == "HUBITAT") {
} else {
