I want to create rules that trigger, or not, based on a hub variable of type boolean.
I want to be able to toggle those triggers using a Zwave button.
But there doesn't appear to be an easy way to toggle a boolean based on a trigger?
OK, I see it now, you have to go in a little deaper than I was going into the variable settings.
Thank you!
Correct me if I am wrong, but I believe that's exactly what I posted above in the first reply to the OP.
Well, yes, but you just showed the rule summary, @bravenel actually showed how to do it.
And we both learned something from them. I haven't had a need to use this but now I know ![]()
