Apps automatically have a Next button, but can you make a "Back"?
I tried using HSM-like buttons in app? as a guide but you can't return a dynamicPage from the appButtonHandler. The only way I can think is adding an href() but of course it will then look very different than the Next button. Any better way to accomplish this?
Say I have
Main Menu -> Option1_Step1 -> Option1_Step2 -> Option1_Step3
So I'm currently on Option1_Step2. Clicking next, the nextPage is set to Option1_Step3. But say I want to get to Option1_Step1. How do I do that? My thought was a Back button making it kind of wizard like. As I said, I can do this by using an href(page: "Option1_Step1") but I can't find a way to do it with a regular button.
Not sure what you mean by "regular button". Every time you want to load a new page, that is either an href, or the Done/Next button. These are dynamic pages, so the definition of nextPage can be dynamic as well. If you want to for from Step 2 to Step 1, change that definition dynamically.
But I can't have two buttons shown at once, a Back and a Next button. Correct? I'm trying to make something that looks like a standard wizard with both Back and Next buttons at the bottom. By "regular button" I meant something the size of the Next button which you can create using an input type:"button" however you can't trigger a page from such a button. Hopefully that helps clarify.
How would I do something like that? First, how'd you get "other stuff" on the same line as the Done button, and second, how do I make it refresh and change the UI when I click one of those buttons?
Not wanting to hijack this thread (I wanted the same as OP) but your above screenshot illustrates a question I had too. How could I create a standalone narrow , say 1/3 screen width, right aligned drop down or edit box or even centralised one without having any element to the left of it ? Is it possible ?
e.g. the 1/3 sized ‘Delete Expression’ field without ‘Insert before’ or the button afterwards. Showing my html unfamiliarity here.. I tried and failed. I wanted a nested/indented text entry field layout.
