Anyone successfully use password with Shelly Plus 1?
When I set a password on my Shelly Plus 1, then enter it in the password field in the device page in Hubitat, I can't control it. Removing the password from both places makes it work. Has anyone here found a way to access a PW protected Shelly in Hubitat?
Dumb question, but does it really matter since it's just a local device?
Older Shelly devices use basic authentication, but Shelly Plus devices use digest authentication.
This likely means that you will need a newer custom driver (which may be true regardless to get all device functionally). I wrote one for personal use that I still need to release. There are a couple of others floating around on the forum.
One last thing to try- what are you setting as the username when you try to configure it with Hubitat? Be sure to try "admin" with the password that you entered.
Yes.
Yes, that worked. Thanks very much!
