Using this I've made a few educated guesses and modified the code a little to hopefully support some additional fan speeds. If this doesn't work, let me know and I'll start adding some debug lines.
i tried the codes, wasn't able to control like the Generic Z-wave plus thermostats driver. There was no reaction from the FCU when i pressed the buttons. Any ideas? Thanks.
Added in the debug lines. In preferences turn on the debug switch (will capture for 30 minutes unless you turn off sooner), and try hitting the Cool, Cooling Setpoint and Fan Speeds; and then do the same functions using the physical buttons on the AirCon unit.
i tried the numbers all dont seems to trigger any functions. I tried using the physical buttons and recorded some functions being triggered. The nearest driver that could work was the Z-wave generic plus thermostat but it also seems like some functions are not available..
If you can grab the debug lines from the logs when you do the physical key presses, it may be possible to reverse engineer them and have the driver issue those commands.
