Hi
I have a problem to adding a Schlage BE468 ZP with Z-wave.
When I tried connect, It show up security message such as blow.
Security question
Security 2 Class 2 Access Control
Security 2 Class 1 Authenticated
Security 2 Class 0 Unauthenticated
Security 0 Unauthenticated
When I choose S2C2, it asks 5digit cord
I don't know Where can I find 5 digit cord.
Hubitat sys on the device label but I did not see.
When I choose S2C0, it does not ask 5 digit cord but unable to continue to adding.
I've been trying for over an hour now to pair my lock with my C7. My programming code is 6 digits and not 5. So I tried using the first 5 digits of my programming code and it still fails every time.
I've tried factory resetting the lock multiple times. I've tried excluding and readding the lock about 100 times.
I'm pretty sure the programming code is not the correct code. It's not the right length and nor does it appear to work (whether I use the first 5 digits or the whole 6 digits).
On the left is the mounting plate that goes against the inside of the door. On the mounting plateβs sticker, just below the QR code, is a rectangle surrounding the five digit security PIN that is needed for secure pairing. This five digit PIN is the same as the first 5 digits of the DSK, shown in small type at the bottom of the sticker.
On the right, at the top of the back of the inside-door module, is a sticker with the serial number, the model (BE469ZP), and 3 codes: the six-digit programming code that is used to configure the lock, and the two four-digit user codes that are initially installed on your lock as positions 1 and 2 when you factory reset the lock.
