In the App i'm getting the error : com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'SensiboPod' in namespace 'velowolf' not found on line 548 (updated)
In the Driver i'm getting the error java.lang.NullPointerException: Cannot invoke method pollChild() on null object on line 299 (refresh)
Thank you @VeloWulf for this great app/driver! One question for you - when I try to add my Sensibo devices to SharpTools, they only show up as a switch rather than as a thermostat - is this because of what you mentioned in post 136?
Hello!
Firstly thank you for all the awesome work. If not for all the help it would be hard for a normal person to set up a smart home.
I was installing my Sensibo and used Velowulf's app and driver code.
I managed to get my pod devices installed. The control within the device tab works. i.e I can on, off etc.
But I tried to put them as thermostat on the habitat dashboard but they can't seem to get the status. All I get are unknowns from the status. i.e "mode" and "fan mode" on the thermostat tile.
Any ideal why that is? I am unable to trigger the sensibo device as well from the tile. Changed mode to cool does not trigger the sensible sky v2.
Thanks!
Yes it’s strange.
The device page is good. Shows all the correct settings. I can use all the switches there as well to on off the device.
Somehow the dashboard is unable to link the tile to the device properly.
Maybe try to rebuild that dashboard or create another and see if it works ok? Can't think what else to try oh, you can also try refreshing the devices using the Sensibo integration App, although if the device pages work OK then that wouldn't seem necessary. Sorry, I'm stumped.
Oh I forgot to add.
If I add it as a switch tile it works to on and off the sensibo device.
So it looks like it's the tile problem? Or is there some reference the tile takes that's the issue.
Yes have tried that.
Created a new dashboard page and added it again as well but same problem.
Tried deleting everything and readding the app and devices. still not working.
I have actually removed our Sensibos from the Hubitat system now and linked them directly to Google Home for voice control, and otherwise we just use the Sensibo app. The main problem I was experiencing is that the account link kept needing to be reconnected. It wasn't a huge task to reconnect but they tended to be disconnected just when we needed them and when it wasn't convenient to reconnect right then! So the overhead to the HE system became not worth it. Similar problem with Netatmo but for now I need that as the outdoor temp sensor is an important part of my automations
You’re using Velowulf’s simplified version, or the original port from the Smartthings code? The latter works as a thermostat tile for me, but not the former - I thought that Velowulf said it wouldn’t too?
