Anybody using a Sensibo?
You need to specify stopped a string, so probably:
tData.data.swing = "stopped"
I didn't write the code for this app/device handler - It's just a port of EricG's implementation for the ST Hub. Mostly just removing some imports and statements, or defining variables that Hubitat needs to function in a similar manner. I noticed some small issues with the code I previously pasted, and EricG has posted an update for the app and DTH. Here's an updated version that I'm using in Hubitat. I've added in a statement to try to catch the null swing modes. Not sure if that solves your problem, but it's worth a try.
Device Handler
 *  Sensibo
 *  Copyright 2015 Eric Gosselin
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
preferences {
metadata {
	definition (name: "SensiboPod", namespace: "EricG66", author: "Eric Gosselin", oauth: false) {
		capability "Relative Humidity Measurement"
		capability "Temperature Measurement"
		capability "Polling"
        capability "Refresh"
        capability "Switch"
        capability "Thermostat"
        capability "Battery"
        capability "Actuator"
        capability "Sensor"
        capability "Health Check"
        capability "Power Source"
        capability "Voltage Measurement"
        attribute "swing", "String"
        attribute "temperatureUnit","String"
        attribute "productModel","String"
        attribute "firmwareVersion","String"
        attribute "Climate","String"
		attribute "targetTemperature","Double"
        attribute "statusText","String"
        attribute "currentmode","String"
        attribute "fanLevel","String"
        command "setAll"
        command "switchFanLevel"
        command "switchMode"
        command "raiseCoolSetpoint"
        command "lowerCoolSetpoint"
        command "raiseHeatSetpoint"
        command "lowerHeatSetpoint"
        command "voltage"
        command "raiseTemperature"
        command "lowerTemperature"
        command "switchSwing"
        command "setThermostatMode"
        command "modeHeat"
        command "modeCool"
        command "modeDry"
        command "modeFan"
        command "modeAuto"
        command "lowfan"
        command "mediumfan"
        command "highfan"
        command "quietfan"
        command "strongfan"
        command "autofan"
        command "fullswing"
        command "setAirConditionerMode"
        command "toggleClimateReact"
        command "setClimateReact"
        command "configureClimateReact"
	simulator {
	tiles(scale: 2) {
    	multiAttributeTile(name:"thermostatMulti", type:"thermostat",, width:6, height:4,canChangeIcon: false) {
   			tileAttribute("device.temperature", key: "PRIMARY_CONTROL") {
            	attributeState ("default", label:'${currentValue}°')//,
                //backgroundColors:[
				//	[value: 15, color: "#153591"],
				//	[value: 18, color: "#1e9cbb"],
				//	[value: 21, color: "#90d2a7"],
				//	[value: 24, color: "#44b621"],
				//	[value: 27, color: "#f1d801"],
				//	[value: 30, color: "#d04e00"],
				//	[value: 33, color: "#bc2323"],
                //    [value: 59, color: "#153591"],
				//	[value: 64, color: "#1e9cbb"],
				//	[value: 70, color: "#90d2a7"],
				//	[value: 75, color: "#44b621"],
				//	[value: 81, color: "#f1d801"],
				//	[value: 86, color: "#d04e00"],
				//	[value: 91, color: "#bc2323"]
            tileAttribute("device.targetTemperature", key: "VALUE_CONTROL") {
                attributeState("VALUE_UP", action: "raiseTemperature")
                attributeState("VALUE_DOWN", action: "lowerTemperature")
            tileAttribute("device.humidity", key: "SECONDARY_CONTROL") {
   				attributeState("default", label:'${currentValue}%', unit:"%")
            tileAttribute("device.thermostatOperatingState", key: "OPERATING_STATE") {
    			attributeState("idle", backgroundColor:"#a9a9a9")
    			attributeState("heating", backgroundColor:"#e86d13")
    			attributeState("cooling", backgroundColor:"#00a0dc")
                attributeState("fan only", backgroundColor:"#44b621")
                attributeState("Dry", backgroundColor:"#A1E5E5")
  			tileAttribute("device.thermostatMode", key: "THERMOSTAT_MODE") {
    			attributeState("off", label:'${name}')
                attributeState("heat", label:'${name}')
                attributeState("cool", label:'${name}')
                attributeState("fan", label:'${name}')
                attributeState("dry", label:'${name}')
    			attributeState("auto", label:'${name}')
  			tileAttribute("device.heatingSetpoint", key: "HEATING_SETPOINT") {
    			attributeState("default", label:'${currentValue}')
  			tileAttribute("device.coolingSetpoint", key: "COOLING_SETPOINT") {
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'Temp: ${currentValue}',backgroundColors:[])
		valueTile("humidity", "device.humidity", width: 2, height: 2) {
			state("humidity", label:'Humidity: ${currentValue} %',
				backgroundColors:[
        valueTile("voltage", "device.voltage", width: 1, height: 1) {
			state("voltage", label:'${currentValue}',
				backgroundColors:[
					[value: 2700, color: "#CC0000"],
					[value: 2800, color: "#FFFF00"],
					[value: 2900, color: "#00FF00"]
        valueTile("firmwareVersion", "device.firmwareVersion", width: 1, height: 1) {
			state("version", label:'Firmware: ${currentValue}',backgroundColors:[])
        valueTile("productModel", "device.productModel", width: 1, height: 1) {
			state("mains", label:'Model: ${currentValue}',backgroundColors:[])
        valueTile("powerSource", "device.powerSource", width: 1, height: 1) {
			state("mains", icon:"https://image.ibb.co/inKcN5/cable_power_cord_plug_circle_512.png", label:'Source: ${currentValue}',backgroundColors:[])
            state("battery", icon:"https://image.ibb.co/gFUNpk/battery.jpg", label:'Source: ${currentValue}',backgroundColors:[])
        standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
			state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc"
			state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff"
        standardTile("fanLevel", "device.fanLevel", width: 2, height: 2) {
            state "low", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/gZxHpk/fan_low_2.png", nextState:"medium"
            state "medium", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/cUa3Uk/fan_medium_2.png", nextState:"high"
            state "high", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/fcfFaQ/fan_high_2.png", nextState:"auto"
            state "auto", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/m8oq9k/fan_auto_2.png" , nextState:"quiet"
            state "quiet", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/mC74wb/fan_quiet2.png" , nextState:"medium_high"
            state "medium_high", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/j62DXR/fan_medium_3.png" , nextState:"medium_low"
            state "medium_low", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/etX296/fan_low_3.png" , nextState:"strong"
            state "strong", action:"switchFanLevel", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/eaLeUw/fan_strong2.png" , nextState:"low"
        standardTile("currentmode", "device.thermostatMode",  width: 2, height: 2) {
            state "heat", action:"switchMode", backgroundColor:"#e86d13", icon:"https://image.ibb.co/c7Grh5/sun.png", nextState:"cool"
            state "cool", action:"switchMode", backgroundColor:"#00a0dc", icon:"https://image.ibb.co/bZ56FQ/cold.png", nextState:"fan"
            state "fan", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/n1dhpk/status_message_fan.png", nextState:"dry"
            state "dry", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/k2ZNpk/dry_mode.png", nextState:"auto"
            state "auto", action:"switchMode", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/dwaRh5/auto_mode.png", nextState:"heat"
        standardTile("upCoolButtonControl", "device.targetTemperature", inactiveLabel: false, decoration: "flat", width: 1, height: 2) {
			state "setpoint", action:"raiseCoolSetpoint", icon:"st.thermostat.thermostat-up",label :"Up"
        standardTile("downCoolButtonControl", "device.targetTemperature", inactiveLabel: false, decoration: "flat", width: 1, height: 2) {
			state "setpoint", action:"lowerCoolSetpoint", icon:"st.thermostat.thermostat-down", label :"Down"
        standardTile("swing", "device.swing",  width: 2, height: 2) {
            state "stopped", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/iWhvaQ/stopped.png", nextState:"fixedTop"
            state "fixedTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/nbV3Uk/fixedTop.png", nextState:"fixedMiddleTop"
            state "fixedMiddleTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/chbcpk/fixed_Middle_Top.png", nextState:"fixedMiddle"
            state "fixedMiddle", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dxDe25/fixed_Middle.png", nextState:"fixedMiddleBottom"
            state "fixedMiddleBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/ebZmh5/fixed_Middle_Bottom.png", nextState:"fixedBottom"
            state "fixedBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/n2tCN5/fixed_Bottom.png", nextState:"rangeTop"
            state "rangeTop", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/gYQsN5/rangeTop.png", nextState:"rangeMiddle"
            state "rangeMiddle", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dC1XN5/range_Middle.png", nextState:"rangeBottom"
            state "rangeBottom", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/csTOUk/range_Bottom.png", nextState:"rangeFull"
            state "rangeFull", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/hHK8vQ/range_Full.png", nextState:"horizontal"
            state "horizontal", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/cAGQ2G/range_Horizontal2.png", nextState:"both"
            state "both", action:"switchSwing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/dLUOpw/range_Both2.png", nextState:"stopped"
        standardTile("Climate", "device.Climate", width: 2, height: 2) {
			state "on", label:'${name}', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#00a0dc"
			state "off", label:'${name}', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#ffffff"
            state "notdefined", label:'N/A', action:"toggleClimateReact", icon:"https://i.ibb.co/Z8ZzcHR/auto-fix-2.png", backgroundColor:"#e86d13"
        standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:"Refresh", action:"refresh.refresh", icon:"st.secondary.refresh"
        standardTile("coolmode", "device.thermostatMode",  width: 1, height: 1) {
       		state "cool", action:"modeCool", backgroundColor:"#00a0dc", icon:"https://image.ibb.co/bZ56FQ/cold.png"
        standardTile("heatmode", "device.thermostatMode",  width: 1, height: 1) {
       		state "heat", action:"modeHeat", backgroundColor:"#e86d13", icon:"https://image.ibb.co/c7Grh5/sun.png"
        standardTile("drymode", "device.thermostatMode",  width: 1, height: 1) {
       		state "dry", action:"modeDry", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/k2ZNpk/dry_mode.png"
        standardTile("fanmode", "device.thermostatMode",  width: 1, height: 1) {
       		state "fan", action:"modeFan", backgroundColor:"#e8e3d8", icon:"https://image.ibb.co/n1dhpk/status_message_fan.png"
        standardTile("highfan", "device.fanLevel",  width: 1, height: 1) {
       		state "high", action:"highfan", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/fcfFaQ/fan_high_2.png"
        standardTile("autofan", "device.fanLevel",  width: 1, height: 1) {
       		state "auto", action:"autofan", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/m8oq9k/fan_auto_2.png"
        standardTile("fullswing", "device.swing",  width: 1, height: 1) {
       		state "rangeFull", action:"fullswing", backgroundColor:"#8C8C8D", icon:"https://image.ibb.co/hHK8vQ/range_Full.png"
		main (["switch"])
		details (["thermostatMulti","switch","fanLevel","currentmode","swing","Climate","refresh","coolmode","heatmode","fanmode","drymode","highfan","autofan","fullswing","firmwareVersion","productModel","powerSource","voltage"])
def setAll(newMode,temp,fan)
	log.trace "setAll() called with " + newMode + "," + temp + "," + fan
    def Setpoint = temp.toInteger()
    def LevelBefore = fan
    def capabilities = parent.getCapabilities(device.deviceNetworkId,newMode)
    def Level = LevelBefore
    if (capabilities.remoteCapabilities != null) {
    	def fanLevels = capabilities.remoteCapabilities.fanLevels
    	log.debug "Fan levels capabilities : " + capabilities.remoteCapabilities.fanLevels
        Level = GetNextFanLevel(LevelBefore,capabilities.remoteCapabilities.fanLevels)
        log.debug "Fan : " + Level
        def result = parent.setACStates(this, device.deviceNetworkId, "on", newMode, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
        if (result) {
        	if (LevelBefore != Level) {
                generatefanLevelEvent(Level)
            sendEvent(name: 'thermostatMode', value: newMode, displayed: false,isStateChange: true)
            if (device.currentState("on").value == "off") { generateSwitchEvent("on") }
            generateModeEvent(newMode)
            generateStatusEvent()
            refresh()
        else {
            generateErrorEvent()
    else {
def lowfan()
	log.trace "lowfan() called"
	dfanLevel("low")
def mediumfan()
	log.trace "mediumfan() called"
	dfanLevel("medium")
def highfan()
	log.trace "highfan() called"
	dfanLevel("high")
def quietfan()
	log.trace "quietfan() called"
	dfanLevel("quiet")
def strongfan()
	log.trace "strongfan() called"
	dfanLevel("strong")
def autofan()
	log.trace "autofan() called"
	dfanLevel("auto")
def fullswing()
	log.trace "fullswing() called"
	modeSwing("rangeFull")
def temperatureDown(temp)
	log.trace "temperatureDown() called with "+ temp
	def sunit = device.currentValue("temperatureUnit")
    def capabilities = parent.getCapabilities(device.deviceNetworkId, device.currentState("currentmode").value)
    def values
    if (sunit == "F") {
    	if (capabilities.remoteCapabilities.temperatures.F == null) {
       		return -1
    	values = capabilities.remoteCapabilities.temperatures.F.values
    else {
    	if (capabilities.remoteCapabilities.temperatures.C == null) {
       		return -1
    	values = capabilities.remoteCapabilities.temperatures.C.values
    def found = values.findAll{number -> number < temp}
	log.debug "Values retrieved : " + found
    if (found == null || found.empty) found = values.first()
    else found = found.last()
    log.debug "Temp before : " + temp
    log.debug "Temp after : " + found
    temp = found
    return temp
def temperatureUp(temp)
	log.trace "temperatureUp() called with "+ temp
    def values
    if (sunit == "F") {
       		return -1
    else {
       		return -1
    def found = values.findAll{number -> number > temp}
    if (found == null || found.empty) found = values.last()
    else found = found.first()
    temp = found
    return temp
void raiseTemperature() {
	log.trace "raiseTemperature() called"
	def operMode = device.currentState("currentmode").value
    def Setpoint = device.currentValue("targetTemperature").toInteger()
    def theTemp = device.currentValue("temperatureUnit")
    log.debug "Current target temperature = ${Setpoint}"
	Setpoint = temperatureUp(Setpoint)
    if (Setpoint == -1) {
      return
    switch (operMode) {
    	case "heat":
        	setHeatingSetpoint(Setpoint)
            break;
        case "cool":
        	setCoolingSetpoint(Setpoint)
            break;
        case "fan":
        	setFanSetpoint(Setpoint)
        	break;
         case "dry":
            setDrySetpoint(Setpoint)
        	break;
        case "auto":
        	break;
        default:
        	break;
void lowerTemperature() {
	log.trace "lowerTemperature() called"
	Setpoint = temperatureDown(Setpoint)
      return
    switch (operMode) {
    	case "heat":
            break;
        case "cool":
            break;
        case "fan":
        	break;
         case "dry":
        	break;
        case "auto":
        	break;
        default:
        	break;
void lowerCoolSetpoint() {
   	log.trace "lowerCoolSetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Cooling temperature changed to " + Setpoint + " for " + device.deviceNetworkId
        sendEvent(name: 'coolingSetpoint', value: Setpoint,  displayed: false)
        sendEvent(name: 'thermostatSetpoint', value: Setpoint,  displayed: false)
        generateSetTempEvent(Setpoint)
    	log.debug "New target Temperature = ${Setpoint}"
    	refresh()
	else {
    	log.debug "error"
void setThermostatMode(modes)
	log.trace "setThermostatMode() called"
  	def currentMode = device.currentState("currentmode").value
  	log.debug "switching AC mode from current mode: $currentMode"
  	switch (modes) {
		case "cool":
			modeCool()
			break
		//case "fan":
		//	returnCommand = modeFan()
		//	break
		//case "dry":
		//	returnCommand = modeDry()
		//	break
        case "auto":
	        modeAuto()
			break
        case "heat":
			modeHeat()
			break
        case "off":
            off()
            break
void setAirConditionerMode(modes)
	log.trace "setAirConditionerMode() called"
  	switch (modes) {
		case "cool":
			modeCool()
			break
		case "fanOnly":
        case "fan":
			modeFan()
			break
		case "dry":
			modeDry()
			break
        case "auto":
	        modeAuto()
			break
        case "heat":
			modeHeat()
			break
void raiseCoolSetpoint() {
   	log.trace "raiseCoolSetpoint() called"
    if (result) {
    	refresh()
	else {
void raiseHeatSetpoint() {
	log.trace "raiseHeatSetpoint() called"
    if (result) {
    	log.info "Heating temperature changed to " + Setpoint + " for " + device.deviceNetworkId
        sendEvent(name: 'heatingSetpoint', value: Setpoint, displayed: false)
    	refresh()
	else {
void lowerHeatSetpoint() {
	log.trace "lowerHeatSetpoint() called"
    if (result) {
    	refresh()
	else {
def refresh()
  log.trace "refresh() called"
  poll()
  log.trace "refresh() ended"
// Set Temperature
def setFanSetpoint(temp) {
	log.trace "setFanSetpoint() called"
	temp = temp.toInteger()
	log.debug "setTemperature : " + temp
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "fan", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Fan temperature changed to " + temp + " for " + device.deviceNetworkId
  		generateModeEvent("fan")
        sendEvent(name: 'thermostatSetpoint', value: temp, displayed: false)
    	generateSetTempEvent(temp)
    	refresh()
    else {
// Set Temperature
def setDrySetpoint(temp) {
	log.trace "setDrySetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "dry", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Dry temperature changed to " + temp + " for " + device.deviceNetworkId
  		generateModeEvent("dry")
    	refresh()
    else {
// Set Temperature
def setCoolingSetpoint(temp) {
	log.trace "setCoolingSetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "cool", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Cooling temperature changed to " + temp + " for " + device.deviceNetworkId
  		generateModeEvent("cool")
    	sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
    	//sendEvent(name: 'heatingSetpoint', value: temp, displayed: false)
    	refresh()
    else {
def setHeatingSetpoint(temp) {
	log.trace "setHeatingSetpoint() called"
    def result = parent.setACStates(this, device.deviceNetworkId , "on", "heat", temp, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "Heating temperature changed to " + temp + " for " + device.deviceNetworkId
    	generateModeEvent("heat")
    	//sendEvent(name: 'coolingSetpoint', value: temp, displayed: false)
    	refresh()
    else {
def generateSetTempEvent(temp) {
   sendEvent(name: "targetTemperature", value: temp, descriptionText: "$device.displayName set temperature is now ${temp}", displayed: true, isStateChange: true)
// Turn off or Turn on the AC
def on() {
	log.trace "on called"
    log.debug "Temp Unit : " + device.currentState("temperatureUnit").value
    def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    log.debug "Result : " + result
    if (result) {
    	log.info "AC turned ON for " + device.deviceNetworkId
    	sendEvent(name: 'thermostatMode', value: device.currentState("currentmode").value, displayed: false,isStateChange: true)
        //sendEvent(name: 'thermostatOperatingState', value: "idle",isStateChange: true)
    	refresh()
    else {
def off() {
	log.trace "off called"
    def result = parent.setACStates(this, device.deviceNetworkId, "off", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, device.currentState("swing").value, device.currentState("temperatureUnit").value)
    if (result) {
    	log.info "AC turned OFF for " + device.deviceNetworkId
    	sendEvent(name: 'thermostatMode', value: "off", displayed: false,isStateChange: true)
        generateSwitchEvent("off")
    	refresh()
    else {
def generateSwitchEvent(mode) {
   sendEvent(name: "on", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: false, isStateChange: true)
   sendEvent(name: "switch", value: mode, descriptionText: "$device.displayName is now ${mode}", displayed: true, isStateChange: true)
   //refresh()
def dfanLevel(String newLevel){
	log.trace "dfanLevel called with fan = " + newLevel
        Level = GetNextFanLevel(newLevel,capabilities.remoteCapabilities.fanLevels)
        //log.debug "Fan : " + Level
        def result = parent.setACStates(this, device.deviceNetworkId,"on", device.currentState("currentmode").value, Setpoint, Level, device.currentState("swing").value, device.currentState("temperatureUnit").value)
        if (result) {
        	log.info "Fan level changed to " + Level + " for " + device.deviceNetworkId
            if (Level == "low") {
            	sendEvent(name: 'thermostatFanMode', value: "circulate", displayed: false)
            else {
                sendEvent(name: 'thermostatFanMode', value: "on", displayed: false)
        	refresh()
        else {
    else {
    	//TODO when the mode do not exist
def generatefanLevelEvent(mode) {
   sendEvent(name: "fanLevel", value: mode, descriptionText: "$device.displayName fan level is now ${mode}", displayed: true, isStateChange: true)
// toggle Climate React
def toggleClimateReact()
  	log.trace "toggleClimateReact() called"
	def currentClimateMode = device.currentState("Climate")?.value
    def returnCommand
    switch (currentClimateMode) {
    	case "off":
        	returnCommand = setClimateReact("on")
            break
        case "on":
        	returnCommand = setClimateReact("off")
            break
    if (!returnCommand) { returnCommand }
// Set Climate React
def setClimateReact(ClimateState) {
    /// Parameter ClimateState : "on" or "off"
	log.trace "setClimateReact() called"
	log.debug "Climate : " + ClimateState
    def result = parent.setClimateReact(this, device.deviceNetworkId, ClimateState)
    if (result) {
    	log.info "Climate React changed to " + ClimateState + " for " + device.deviceNetworkId
        sendEvent(name: 'Climate', value: ClimateState, displayed: false)
    	//generateSetTempEvent(temp)
    	refresh()
    else {
def configureClimateReact(lowThres, highThres,stype,lowState,highState, on_off, ThresUnit)
    // lowThres and highThres - Integer parameters
	// stype : possible values are "temperature", "humidity" or "feelsLike"
    // lowState and highState :
    //    on, fanLevel, temperatureUnit, targetTemperature, mode
    //    like  "[true,'auto','C',21,'heat']"
    //    to turn off AC,first parameters = false : "[false,'auto','C',21,'heat']"
    // one_off : boolean value to enable/disable the Climate React
    // unit : Passing F for Farenheit or C for Celcius
    // Some examples:
    // Range 19-24 Celcius, start to heat to 22 at auto fan if the temp is lower than 19 and stop the AC when higher than 24
    // configureClimateReact(19, 24, ‘temperature’, ‘[true, ‘auto’, ‘C’, 22, ‘heat’]’, ‘[false, ‘auto’, ‘C’, 22, ‘heat’]’, true, ‘C’);
    // Range 67-68 Farenheit, start to heat to 68 at auto fan if the temp is lower than 67 and stop the AC when higher than 68
    // configureClimateReact(67, 68, ‘temperature’, ‘[true, ‘auto’, ‘F’, 68, ‘heat’]’, ‘[false, ‘auto’, ‘F’, 68, ‘heat’]’, true, ‘F’);
	log.trace "configureClimateReact() called"
    if (ThresUnit.toUpperCase() == "F")
    	lowThres = fToc(lowThres).round(1)
    	highThres = fToc(highThres).round(1)
    def json = new groovy.json.JsonBuilder()
    def lowStateMap = evaluate(lowState)
    def highStateMap = evaluate(highState)
    def lowStateJson
    def highStateJson
    if (lowStateMap) {
        lowStateJson = json {
            on lowStateMap[0]
            fanLevel lowStateMap[1]
            temperatureUnit lowStateMap[2]
            targetTemperature lowStateMap[3]
            mode lowStateMap[4]
    else { lowStateJson = null }
    if (highStateMap) {
        highStateJson = json {
            on highStateMap[0]
            fanLevel highStateMap[1]
            temperatureUnit highStateMap[2]
            targetTemperature highStateMap[3]
            mode highStateMap[4]
    else { highStateJson = null }
    def root = json {
    	deviceUid device.deviceNetworkId
        highTemperatureWebhook null
        highTemperatureThreshold highThres
        lowTemperatureWebhook null
        type stype
        lowTemperatureState lowStateJson
        enabled on_off
        highTemperatureState highStateJson
        lowTemperatureThreshold lowThres
    log.debug "CLIMATE REACT STRING : " + JsonOutput.prettyPrint(json.toString())
    def result = parent.configureClimateReact(this, device.deviceNetworkId, json.toString())
    if (result) {
    	log.info "Climate React settings changed for " + device.deviceNetworkId
        sendEvent(name: 'Climate', value: on_off, displayed: false)
    	refresh()
    else {
def switchFanLevel() {
	log.trace "switchFanLevel() called"
	def currentFanMode = device.currentState("fanLevel")?.value
	log.debug "switching fan level from current mode: $currentFanMode"
	def returnCommand
	switch (currentFanMode) {
		case "low":
			returnCommand = dfanLevel("medium")
			break
		case "medium":
			returnCommand = dfanLevel("high")
			break
		case "high":
			returnCommand = dfanLevel("auto")
			break
        case "auto":
			returnCommand = dfanLevel("quiet")
			break
        case "quiet":
			returnCommand = dfanLevel("medium_high")
			break
         case "medium_high":
			returnCommand = dfanLevel("medium_low")
			break
         case "medium_low":
			returnCommand = dfanLevel("strong")
			break
          case "strong":
			returnCommand = dfanLevel("low")
			break
	returnCommand
def modeHeat()
	log.trace "modeHeat() called"
	modeMode("heat")
def modeCool()
	log.trace "modeCool() called"
	modeMode("cool")
def modeDry()
	log.trace "modeDry() called"
	modeMode("dry")
def modeFan()
	log.trace "modeFan() called"
	modeMode("fan")
def modeAuto()
	log.trace "modeAuto() called"
	modeMode("auto")
// To change the AC mode
def switchMode() {
	log.trace "switchMode() called"
	def currentMode = device.currentState("currentmode")?.value
	def returnCommand
	switch (currentMode) {
		case "heat":
			returnCommand = modeMode("cool")
			break
		case "cool":
			returnCommand = modeMode("fan")
			break
		case "fan":
			returnCommand = modeMode("dry")
			break
        case "dry":
            returnCommand = modeMode("auto")
			break
        case "auto":
			returnCommand = modeMode("heat")
			break
	returnCommand
def modeMode(String newMode){
    log.trace "modeMode() called with " + newMode
    def LevelBefore = device.currentState("fanLevel").value
        if (result) {
        	log.info "Mode changed to " + newMode + " for " + device.deviceNetworkId
        	refresh()
        else {
    else {
       def themodes = parent.getCapabilities(device.deviceNetworkId,"modes")
       def sMode = GetNextMode(newMode,themodes)
	   NextMode(sMode)
def generateModeEvent(mode) {
   sendEvent(name: "thermostatMode", value: mode, descriptionText: "$device.displayName Thermostat mode is now ${mode}", displayed: true, isStateChange: true)
def returnNext(liste1, liste2, val) throws Exception
    try {
    	def index = liste2.indexOf(val)
        if (index == -1) throw new Exception()
        else return liste2[liste2.indexOf(val)]
    catch(Exception e) {
    	if (liste1.indexOf(val)+ 1 == liste1.size()) {
           val = liste1[0]
         else {
           val = liste1[liste1.indexOf(val) + 1]
def GetNextFanLevel(fanLevel, fanLevels)
	log.trace "GetNextFanLevel called with " + fanLevel
    if (fanLevels == null || fanLevels == "null") {
      return null
	def listFanLevel = ['low','medium','high','auto','quiet','medium_high','medium_low','strong']
    def newFanLevel = returnNext(listFanLevel, fanLevels,fanLevel)
    log.debug "Next fanLevel = " + newFanLevel
    return newFanLevel
def GetNextMode(mode, modes)
	log.trace "GetNextMode called with " + mode
	def listMode = ['heat','cool','fan','dry','auto']
    def newMode = returnNext(listMode, modes,mode)
    log.debug "Next Mode = " + newMode
	return newMode
def NextMode(sMode)
	log.trace "NextMode called()"
	if (sMode != null) {
    	switch (sMode)
         	case "heat":
            	modeHeat()
            	break
            case "cool":
            	modeCool()
            	break
            case "fan":
            	modeFan()
            	break
            case "dry":
            	modeDry()
            	break
            case "auto":
            	modeAuto()
            	break
    else
    	return null
def GetNextSwingMode(swingMode, swingModes){
	log.trace "GetNextSwingMode() called with " + swingMode
    if (swingModes == null || swingModes == "null") {
    	return null
	def listSwingMode = ['stopped','fixedTop','fixedMiddleTop','fixedMiddle','fixedMiddleBottom','fixedBottom','rangeTop','rangeMiddle','rangeBottom','rangeFull','horizontal','both']
    def newSwingMode = returnNext(listSwingMode, swingModes,swingMode)
    log.debug "Next Swing Mode = " + newSwingMode
	return newSwingMode
def switchSwing() {
	log.trace "switchSwing() called"
	def currentMode = device.currentState("swing")?.value
	log.debug "switching Swing mode from current mode: $currentMode"
	def returnCommand
		case "stopped":
			returnCommand = modeSwing("fixedTop")
			break
		case "fixedTop":
			returnCommand = modeSwing("fixedMiddleTop")
			break
        case "fixedMiddleTop":
			returnCommand = modeSwing("fixedMiddle")
			break
        case "fixedMiddle":
			returnCommand = modeSwing("fixedMiddleBottom")
			break
        case "fixedMiddleBottom":
			returnCommand = modeSwing("fixedBottom")
			break
		case "fixedBottom":
			returnCommand = modeSwing("rangeTop")
			break
        case "rangeTop":
            returnCommand = modeSwing("rangeMiddle")
			break
        case "rangeMiddle":
			returnCommand = modeSwing("rangeBottom")
			break
         case "rangeBottom":
			returnCommand = modeSwing("rangeFull")
			break
        case "rangeFull":
			returnCommand = modeSwing("horizontal")
			break
        case "horizontal":
			returnCommand = modeSwing("both")
			break
         case "both":
			returnCommand = modeSwing("stopped")
			break
	returnCommand
def modeSwing(String newSwing)
    log.trace "modeSwing() called with " + newSwing
    def SwingBefore = device.currentState("swing").value
    def Swing = SwingBefore
    	def Swings = capabilities.remoteCapabilities.swing
        log.debug "Swing capabilities : " + capabilities.remoteCapabilities.swing
        Swing = GetNextSwingMode(newSwing,capabilities.remoteCapabilities.swing)
        //log.debug "Swing : " + Swing
        def result = parent.setACStates(this, device.deviceNetworkId, "on", device.currentState("currentmode").value, Setpoint, device.currentState("fanLevel").value, Swing, device.currentState("temperatureUnit").value)
        if (result) {
        	log.info "Swing mode changed to " + Swing + " for " + device.deviceNetworkId
            sendEvent(name: 'swing', value: Swing, displayed: false,isStateChange: true)
            generateSwingModeEvent(Swing)
        	refresh()
        else {
    else
      //TODO
def generateSwingModeEvent(mode) {
   sendEvent(name: "swing", value: mode, descriptionText: "$device.displayName swing mode is now ${mode}", displayed: true, isStateChange: true)
def generateErrorEvent() {
   log.debug "$device.displayName FAILED to set the AC State"
   sendEvent(name: "Error", value: "Error", descriptionText: "$device.displayName FAILED to set or get the AC State", displayed: true, isStateChange: true)
void poll() {
	log.trace "Executing 'poll' using parent SmartApp"
	def results = parent.pollChild(this)
    def linkText = getLinkText(device)
    parseTempUnitEventData(results)
    parseEventData(results)
def parseTempUnitEventData(Map results)
    log.debug "parsing data $results"
	if(results)
		results.each { name, value ->
        	if (name=="temperatureUnit") {
                def isChange = true
                def isDisplayed = false
				sendEvent(
					value: value,
                    //unit: value,
					linkText: linkText,
					descriptionText: "${name} = ${value}",
					handlerName: "temperatureUnit",
					isStateChange: isChange,
					displayed: isDisplayed)
def parseEventData(Map results)
	log.debug "parsing Event data $results"
	if(results)
 			log.debug "name :" + name + " value :" + value
            def isChange = false
            def isDisplayed = true
            if (name=="voltage") {
                isChange = true //isTemperatureStateChange(device, name, value.toString())
                isDisplayed = false
				sendEvent(
					value: value,
                    unit: "mA",
					linkText: linkText,
					descriptionText: getThermostatDescriptionText(name, value, linkText),
					handlerName: name,
            else if (name== "battery") {
                isDisplayed = false
				sendEvent(
					value: value,
                    //unit: "V",
					linkText: linkText,
					handlerName: name,
            else if (name== "powerSource") {
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name== "Climate") {
                isChange = true
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="on") {
                isChange = true
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
                sendEvent(name: "switch", value: value)
            else if (name=="thermostatMode") {
                isDisplayed = false
				if (value=="cool") {
                	sendEvent(name: 'airConditionerMode', value: "cool",
                    sendEvent(name: 'thermostatOperatingState', value: "cooling",
				} else if (value=="heat") {
					sendEvent(name: 'airConditionerMode', value: "heat",
                    sendEvent(name: 'thermostatOperatingState', value: "heating",
				} else if (value=="fan") {
             		sendEvent(name: 'airConditionerMode', value: "fanOnly",
					sendEvent(name: 'thermostatOperatingState', value: "fan only",
                } else if (value=="dry") {
                    sendEvent(name: 'airConditionerMode', value: "dry",
					sendEvent(name: 'thermostatOperatingState', value: "dry",
                 } else if (value=="auto") {
                    sendEvent(name: 'airConditionerMode', value: "auto",
					sendEvent(name: 'thermostatOperatingState', value: "auto",
				} else {
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="coolingSetpoint" || name== "heatingSetpoint" || name == "thermostatSetpoint") {
                isDisplayed = false
				sendEvent(
					value: value,
                    //unit : device.currentValue("temperatureUnit"),
					linkText: linkText,
					handlerName: name,
            else if (name=="temperatureUnit") {
                isChange = true
                isDisplayed = false
				sendEvent(
					value: value,
                    //unit: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="thermostatFanMode") {
            	def mode = (value.toString() == "high" || value.toString() == "medium") ? "on" : value.toString()
                mode = (mode == "low") ? "circulate" : mode
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
 			else if (name=="swing") {
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else if (name=="temperature" || name== "lastTemperaturePush" || name== "lastHumidityPush") {
                isDisplayed = false
				sendEvent(
					value: value,
					//unit: device.currentValue("temperatureUnit"),
					linkText: linkText,
					handlerName: name,
            else if (name=="humidity") {
                isDisplayed = false
				sendEvent(
					value: value,
					linkText: linkText,
					handlerName: name,
            else {
            	isChange = true//isStateChange(device, name, value.toString())
                isDisplayed = false//isChange
                sendEvent(
					value: value.toString(),
					linkText: linkText,
					handlerName: name,
        generateStatusEvent ()
private getThermostatDescriptionText(name, value, linkText)
	if(name == "temperature")
		return "$name was $value " + device.currentState("temperatureUnit").value
    else if(name == "humidity")
		return "$name was $value %"
    else if(name == "targetTemperature")
		return "latest temperature setpoint was $value " + device.currentState("temperatureUnit").value
	else if(name == "fanLevel")
		return "latest fan level was $value"
	else if(name == "on")
		return "latest switch was $value"
    else if (name == "mode")
        return "thermostat mode was ${value}"
    else if (name == "currentmode")
    else if (name == "powerSource")
        return "power source mode was ${value}"
    else if (name == "Climate")
        return "Climate React was ${value}"
    else if (name == "thermostatMode")
    else if (name == "temperatureUnit")
    	return "thermostat unit was ${value}"
    else if (name == "voltage")
    	return "Battery voltage was ${value}"
    else if (name == "battery")
    	return "Battery was ${value}"
    else if (name == "voltage" || name== "battery")
    else if (name == "swing")
    	return "Swing mode was ${value}"
    else if (name == "Error")
    	def str = (value == "Failed") ? "failed" : "success"
        return "Last setACState was ${str}"
    else
        return "${name} = ${value}"
// parse events into attributes
	log.debug "Parsing '${description}'"
    def name = null
	def value = null
    def statusTextmsg = ""
    def msg = parseLanMessage(description)
    def headersAsString = msg.header // => headers as a string
    def headerMap = msg.headers      // => headers as a Map
    def body = msg.body              // => request body as a string
    def status = msg.status          // => http status code of the response
    def json = msg.json              // => any JSON included in response body, as a data structure of lists and maps
    def xml = msg.xml                // => any XML included in response body, as a document tree structure
    def data = msg.data              // => either JSON or XML in response body (whichever is specified by content-type header in response)
	if (description?.startsWith("on/off:")) {
		log.debug "Switch command"
		name = "switch"
		value = description?.endsWith(" 1") ? "on" : "off"
   else if (description?.startsWith("temperature")) {
    	log.debug "Temperature"
        name = "temperature"
		value = device.currentValue("temperature")
    else if (description?.startsWith("humidity")) {
    	log.debug "Humidity"
        name = "humidity"
		value = device.currentValue("humidity")
    else if (description?.startsWith("targetTemperature")) {
    	log.debug "targetTemperature"
        name = "targetTemperature"
		value = device.currentValue("targetTemperature")
    else if (description?.startsWith("fanLevel")) {
    	log.debug "fanLevel"
        name = "fanLevel"
		value = device.currentValue("fanLevel")
    else if (description?.startsWith("currentmode")) {
    	log.debug "mode"
        name = "currentmode"
		value = device.currentValue("currentmode")
    else if (description?.startsWith("on")) {
    	log.debug "on"
        name = "on"
        value = device.currentValue("on")
    else if (description?.startsWith("switch")) {
    	log.debug "switch"
        name = "switch"
    else if (description?.startsWith("temperatureUnit")) {
    	log.debug "temperatureUnit"
        name = "temperatureUnit"
        value = device.currentValue("temperatureUnit")
    else if (description?.startsWith("Error")) {
    	log.debug "Error"
        name = "Error"
        value = device.currentValue("Error")
    else if (description?.startsWith("voltage")) {
    	log.debug "voltage"
        name = "voltage"
		value = device.currentValue("voltage")
    else if (description?.startsWith("battery")) {
    	log.debug "battery"
        name = "battery"
		value = device.currentValue("battery")
    else if (description?.startsWith("swing")) {
    	log.debug "swing"
        name = "swing"
		value = device.currentValue("swing")
    def result = createEvent(name: name, value: value)
	log.debug "Parse returned ${result?.descriptionText}"
	return result
def generateStatusEvent() {
    def temperature = device.currentValue("temperature").toDouble()
    def humidity = device.currentValue("humidity").toDouble()
    def targetTemperature = device.currentValue("targetTemperature").split(' ')[0].toDouble()
    def fanLevel = device.currentValue("fanLevel")
    def mode = device.currentValue("currentmode")
    def on = device.currentValue("on")
    def swing = device.currentValue("swing")
    def ClimateReact = device.currentValue("Climate")
	def error = device.currentValue("Error")
    def sUnit = device.currentValue("temperatureUnit")
    statusTextmsg = "${humidity}%"
    sendEvent("name":"statusText", "value":statusTextmsg, "description":"", displayed: false, isStateChange: true)
def fToc(temp) {
	return ((temp - 32) / 1.8).toDouble()
def ping(){
	log.trace "calling parent ping()"
	return parent.ping()
