I have looked for a simple app to call Webhooks, but it doesn’t seem to exist. Looks like Shortcuts can but I couldn’t find a watch app. Looking for a simple way to perform goodnight/good morning. Siri would be fine if anyone has bridged Hubitat to that.
I know ifttt works on wear os and you can add buttons and those buttons will trigger anything you want in HE, but I'm not sure if that is a possibility with watch os.
I just looked and ifttt has a watch os app, you can use webhooks in ifttt too
Buying a raspberry pi and installing the Homebridge docker image is so easy. Installing the Homebridge integration is easy too. Now you've got native-ish iOS control over Hubitat.
Take a look at Launcher app. Within the settings you’ll find options to setup your watch. You can add the maker API’s to the app, chose icons, or create your own which will display on your watch. I added the app to the main watch screen and use virtual buttons with ABC app to “toggle” what I want.
You get more options if you upgrade to the paid version, which I did.
