Any Problem Using Both Ecobee Suite with Ecobee Integration
For the last couple of weeks I have been getting LimitExceededException errors. The first one I noticed was on a sendLocationEvent(). I couldn't find the problem so I replace that call using a different means. Soon after that change I started getting errors in the device driver for the Ecobee Therm device. The specific line of code in that driver was a sendEvent(). I have recently done a local backup, reset, and then a local restore and keeping my fingers crossed I won't see the exception any more. But I am curious if it is OK to use both Ecobee Suite along with Ecobee Integration.
Thank You
I’ve been using both for sometime now. Primarily to track all of my remote room sensors separately. I have had no issues.
However, I have found that Ecobee Suite is a bit more resource intensive. Especially, depending upon polling rate. Mine is set to 1 minute. I do this because I do want near realtime update of remote sensors when not home.
