Any other info on Adaptive Lighting app in 2.4.4
I saw the new app in the notes for the release of 2.4.4 " Adaptive Lighting to automatically adjust CT lights temperature to match the diurnal cycle."
Where can I find more information on this new app? I looked around briefly for it and could not find any further info, or the app. Thanks for the help!
Check under Apps -> Add app (or build-in app) -> type in "adaptive" in the search box. It should pop right up.
I don't think it is in the documentation yet, but based upon past new apps, they will have that updated fairly quickly.
That said, the app itself has a helpful graphic that shows what most of the settings are for, and it isn't a complex app like Rule Machine. Many users might even be able to use this app without any editing at all, just pick a bulb and let the app do its thing.
Edit: screenshot of graphic in AL.
What if it is not showing?
In the past, I have had new apps delay showing. It may be a browser caching issue, or just some hub background process hasn't completed.
Try waiting a few minutes or a different browser and see if that makes a difference.
Or maybe this is a bug of some type?
Works for me...
Screenshot 2026-02-13 at 10.03.38 AM
Not arguing with what you are seeing, just sayin' it's not universal. :smiley:
I am running v2.4.4.130 now and I am also not seeing this app available.
Try clearing your browser cache and reload?
Still not showing in Edge, Chrome or IOS app. I have rebooted x2 (switched to JS and did the ZW firmware upgrade) as well as shutting down and restarting. Also cleared cache.
Guess it only works for the cool kids :rofl:
Not showing for me too...
Tried that. Did not work. I don't see it on the mobile app, either.
I have a C-5 hub. Does that matter?
@gopher.ny maybe a bug of some type? A few users above with issues installing the app...
C-8 Pro on 2.4.4.131. I'm not seeing it either.
If you don't see the app, can you run this endpoint:
http://hubs.ip.address.here/hub/advanced/reloadAppAndDriverDefinitions
It does exactly what the name says. Check apps page afterwards. I'll investigate.
Still not showing after running the endpoint, I did get the done message.
Just Updated Today .. Also Not Showing ..
same here. this kind of app is why i got into home automation. Im super excited to try a native version
Same here.
Ditto.
Its nice to know that I was looking in the correct spot this morning and didnt miss something. It is not showing for me as well even after running the endpoint refresh.
