New Hubitat user. Trying to migrate my Alexa devices over to Hub but can't seem to get any recognition of Jinvoo smart switches of which I have six controlled by Alexa. Reset several times, pairing mode activated, but no recognition. Too bad Hubitat can't just capture the Alexa settings.
Are you sure you have zigbee devices?
I was under the impression jinvoo made WiFi devices, and a quick google search of “jinvoo zigbee” didn’t really turn up anything.
Do you have these switches paired directly to an echo plus? Or are you using the jinvoo Alexa skill?
I did finally find a couple of sites that listed the Jinvoo devices as Zigbee - they pair easily to my Alexa account on Show, and android as well as my echo 3 using the Alexa skil for Jinvoo and Smart Home. I also have the Hubitat skill, but have not been successful in adding any devices to the Hubitat to use its Alexa skill
Jinvoo may make zigbee devices; however, the ones you have are WiFi. They don't pair directly to Hubitat. However, this post from @cwwilson08 may help you get them working with Hubitat. It will require the use of an RPi or some other computer that can run nodeJs
Guess I jumped too quickly on the Hubitat Hype before knowing the limitations for my current devices.
WiFi is a limitation on many home automation hubs.... its not just limited to Hubitat. SmartThings does not support WiFi natively either.
