Can you first install the custom driver, then delete it (REMOVE DEVICE button at the bottom of the device page), and then try to pair it again to your C-7 ?
My dev. hub is C-7 and this plug has no problems pairing many times to it .. Works on C-8 also.
My plug is from this site, but it should be the same as yours :
