Why is there no definitive driver solution for this device with no issue?
So I've gone through all the drivers I've found for wd200+ (4) and have narrowed it down to two usable ones, I can go either way if I can understand how to program them because they both SEEM to work as I need them to.
I'm using webcore and trying to set the LED.
The first is the built in one. I can't seem to program this at all in webcore because I don't know how many values go into the parameter and I don't know if they are supposed to be integers, strings, or decimals. And do I set the color as the word like in the device page or a number correlating with the color.
The other one is the community 'Almost Any Dimmer ZWave Plus". This I got working through webcore except for the blinking gets wonky. I can set the bottom LED to blink, but not the others in any logical way. Trying to set numbers 1-7 to correlate with the LED gives undesirable blinking.
I have already tried passing it how I believe matches the device page.....ex, 22,red,1...it does nothing. So sorry, but that doesn't help my issue. Anyone else?
What parameter types are you using. Believe I saw on another thread that the built in driver was expecting all the the parameters to be passed as strings.
As an FYI, I've been doing a almost complete rewrite of that driver and plan to have the Version 2.x.x release out soon (within the week; possibly as soon as tomorrow) The new version is a lot faster during startup and does a lot less polling of the devices during configuration. It also fixes a number of errors in S2 security handling.
Just coming back to update, I figured it out. I messed up on two parts.
1/ I didn't expose the light in webcore as a configurable device, so I wasn't seeing "setStatusLED", and thus using "setParameter"...which oddly enough isn't there anymore.
2/ The parameter values I was using was "integer,string,integer", instead of "string,string,strings" and everything is good now.
Some other issues I'm having now but unrelated to this.
