Finally got rid of the Mr Beams battery powered light I had mounted in the ceiling.
Took me a lot of searching to find this kit so I wanted to share. My fav part is the IR sensor instead of a motion sensor I see with a lot of others. I specifically did NOT want a motion sensor.
https://www.amazon.com/gp/product/B08YDC88FJ/
Since it is right next to the fridge I drilled a hole in the wall and fished the wire through and plugged it in behind the fridge. The wire for the power pack to the sensor was not going to be long enough so I cut excess from the LED lead wire (which was excessively long) and spliced it into the power supply cable. If you add an outlet in the closet it will work as-is, which I will be doing for the Coat Closet next.
The little IR sensor, SHOULD be mounted opposite of the hinge side of the door which I realized after I had the whole thing installed. I thought it would be better on the hinge side, less likely to get banged into. I just had to set it back far enough to detect the small swing on the hinge side. Surprisingly it has just enough room between the floor and that trim to see the door open and close.
No light (how it was when we moved in) vs with LED Strip:
